Threads: 6
Has anyone collected practical experiences with IoT-Devices from Shelly - particularly controlling them from KNX via LM5?
e.g.: interesting applications are mainly in budget-sensitive environments:
- Power-measurement with LM3 for visualisation and triggering event based actions
- Using the Shelly i3 as a wireless-KNX-sensor in a retrofit environment
- Using the Shelly RGBW2 as a KNX to WiFi-RGBW-LED-dimmer in a retrofit environment
... to name a few
Threads: 41
This can be implemented either by using MQTT broker in LM (two-way) or HTTP (remote services to LM, HTTP requests from LM scripts).
Threads: 6
28.11.2020, 14:31
(This post was last modified: 28.11.2020, 14:40 by Todayslife.)
(24.11.2020, 13:35)admin Wrote: This can be implemented either by using MQTT broker in LM (two-way) or HTTP (remote services to LM, HTTP requests from LM scripts). Thanks for the very quick reply :-)
Very well so far, using the MQTT Broker in LM5 sounds indeed promising.
Therefor, one might be really happy getting a more specific answer to the original question; in particular about actual practical experiences - if any exists already - in terms of how to integrate Shelly' IoT-Devices within the LogicMachine's "ecosystem".
(eg. using the LM5's new MQTT Broker).
Hence, trying to precise above question as follows (and please excuse, if this may sound amateurish):
"Has anyone already made practical experiences with IoT-Devices from Shelly? In particular; successfully controlling Shelly-Devices from the KNX-bus via LM5's MQTT Broker"?
Thanks again
Threads: 41
I don't think that anybody has made an integration yet but it's very easy to do. On LM side you need to enable broker and create a script to exchange values between MQTT and LM objects. On Shelly device you need to set MQTT broker address and topic.
Threads: 6
28.11.2020, 15:41
(This post was last modified: 28.11.2020, 15:42 by Todayslife.)
(28.11.2020, 14:55)admin Wrote: I don't think that anybody has made an integration yet but it's very easy to do. On LM side you need to enable broker and create a script to exchange values between MQTT and LM objects. On Shelly device you need to set MQTT broker address and topic. Thank you for the - again - quick response.
Well, just enabling the MQTT-Broker on the LM5 (SW: 20200720) wasn't bringing up much questions as it seemed.
So it appeared as easy on the Shelly-Device to set the MQTT broker's address and topic.
Whereis - for someone being unexperienced and feeling rather uncomfortable writing software - creating a script to exchange values between MQTT and LM objects seems indeed much more troublesome - hence, please excuse, if asking for your help in writing such scripts may try your patience.
Threads: 41
See this thread for a fully working script with two-way exchange between LM objects and MQTT: https://forum.logicmachine.net/showthrea...6#pid10926
You need to set the broker address to 127.0.0.1 and edit mqtt_to_object/object_to_mqtt tables. Make sure that you don't have the same topic mapped to both tables otherwise you can get a loop.
Threads: 5
Sorry, but I'm not able to use the script.
I changed the broker address with 127.0.0.1 (local borker) and modified the mqtt_to_object/object_to_mqtt tables in order to do a simple ON /OFF of an mqtt object (shelly) as example.
My tables has:
mqtt_to_object = {
['shellies/shellyplug-s-??????/relay/0'] = '0/0/12'
where 0/0/12 is the On/Off knx status
and
object_to_mqtt = {
['0/0/11'] = 'shellies/shellyplug-s-??????/relay/0/command'
where 0/0/11 is the On/Off knx command
Shelly want on and off command, not 0 or 1. I used custom value to modify that, but doesn't work
Here is my log:
* arg: 1
* string: mqtt connect status
* arg: 2
* bool: true
* arg: 3
* number: 0
* arg: 4
* string: connection accepted
* arg: 5
* number: 0
* arg: 6
* nil
Thank you
Threads: 41
Modify the script around line 108, change this:
Code: if type(value) == 'boolean' then
value = value and 1 or 0
To this:
value = value and 'on' or 'off'
Also make sure that Shelly MQTT address is not 127.0.0.1 but LM IP address.
Threads: 5
26.12.2020, 21:32
(This post was last modified: 26.12.2020, 21:36 by mdisilvestro.)
Thanks, but something is wrong.
Here is my script:
Code: if not broker then
broker = '127.0.0.1'
function multiply(mult)
return function(value)
local num = tonumber(value)
if num then
return num * mult
return value
-- topic to object map
mqtt_to_object = {
['shellies/shellyplug-s-?????/relay/0'] = '3/0/2'
-- optional topic value conversion function
-- mqtt_to_object_conv = {
-- ['in/topic1'] = multiply(100),
-- ['in/topic2'] = multiply(0.01),
-- object to topic map
object_to_mqtt = {
['3/0/3'] = 'shellies/shellyplug-s-??????/relay/0/command'
datatypes = {}
grp.sender = 'mq'
require('socket')
for addr, _ in pairs(object_to_mqtt) do
local obj = grp.find(addr)
if obj then
datatypes[ addr ] = obj.datatype
mclient = require('mosquitto').new()
mclient.ON_CONNECT = function(res, ...)
log('mqtt connect status', res, ...)
if res then
for topic, _ in pairs(mqtt_to_object) do
mclient:subscribe(topic)
mclient:disconnect()
mclient.ON_MESSAGE = function(mid, topic, payload)
local addr = mqtt_to_object[ topic ]
if addr then
local fn = mqtt_to_object_conv[ topic ]
if fn then
payload = fn(payload)
grp.write(addr, payload)
mclient.ON_DISCONNECT = function(...)
log('mqtt disconnect', ...)
mclientfd = nil
function mconnect()
local fd
mclient:connect(broker)
fd = mclient:socket()
-- fd ref is valid
if fd then
mclientfd = fd
mconnect()
function publishvalue(event)
-- message from us or client is not connected
if event.sender == 'mq' or not mclientfd then
return
local addr = event.dst
local dpt = datatypes[ addr ]
local topic = object_to_mqtt[ addr ]
-- unknown object
if not dpt or not topic then
return
local value = busdatatype.decode(event.datahex, dpt)
if value ~= nil then
mclient:publish(topic, tostring(value))
lbclient = require('localbus').new(1)
lbclient:sethandler('groupwrite', publishvalue)
lbclientfd = socket.fdmaskset(lbclient:getfd(), 'r')
-- run timer every 5 seconds
timer = require('timerfd').new(5)
timerfd = socket.fdmaskset(timer:getfd(), 'r')
-- mqtt connected
if mclientfd then
mclientfdset = socket.fdmaskset(mclientfd, mclient:want_write() and 'rw' or 'r')
res, lbclientstat, timerstat, mclientstat =
socket.selectfds(10, lbclientfd, timerfd, mclientfdset)
-- mqtt not connected
res, lbclientstat, timerstat =
socket.selectfds(10, lbclientfd, timerfd)
if mclientfd and mclientstat then
if socket.fdmaskread(mclientstat) then
mclient:loop_read()
if socket.fdmaskwrite(mclientstat) then
mclient:loop_write()
if lbclientstat then
lbclient:step()
if timerstat then
-- clear armed timer
timer:read()
if mclientfd then
mclient:loop_misc()
mconnect()
LOG1:
* arg: 1
* arg: 2
* bool: false
* arg: 3
* number: 5
* arg: 4
* string: connection refused - not authorized
* arg: 5
* number: 0
* arg: 6
* nil
LOG2:
* arg: 1
* string: mqtt disconnect
* arg: 2
* bool: false
* arg: 3
* number: 0
* arg: 4
* string: unexpected disconnect
* arg: 5
* nil
logging continusly, every 10 seconds
Shelly use correct LM IP for broker device. The MQTT communication works fine, I tested it whit MQTT.fx software.
Simplifing: I want that an "ON" knx telegram became ad an "ON" request through mqtt, and viceversa.
Threads: 41
Are you able to control your Shelly device using an external MQTT client? You can monitor what LM is writing to these topics and check what's wrong. The last change will publish on/off for binary objects.
Threads: 16
I also have a problem with the shelly connection and I don't know what I'm doing wrong. Please if anyone can help.
LM Mqtt broker
MQTT explorer
if num then
return num * mult
return value
mqtt_to_object = {
['shellies/shellyplug-s-D9AA39/relay/0'] = '32/1/1',
['shellies/shellyplug-s-D9AA39/temperature'] = '32/1/2',
['shellies/shellyplug-s-D9AA39/relay/0'] = multiply(1),
['shellies/shellyplug-s-D9AA39/temperature'] = multiply(1),
object_to_mqtt = {
-- ['1/1/1'] = 'out/topic1',
-- ['1/1/2'] = 'out/topic2',
datatypes = {}
grp.sender = 'mq'
require('socket')
if obj then
if res then
if addr then
if fn then
mclientfd = nil
function mconnect()
local fd
-- fd ref is valid
if fd then
mclientfd = fd
mconnect()
return
-- unknown object
return
-- mqtt connected
if mclientfd then
mclient:loop_read()
lbclient:step()
if timerstat then
timer:read()
if mclientfd then
mclient:loop_misc()
mconnect()
LM log
LM Objects
Threads: 41
Add logging to ON_MESSAGE to check that you are getting the data. Also do a full script restart the script via disable/enable.
Code: mclient.ON_MESSAGE = function(mid, topic, payload)
log('message', topic, payload, addr)
if addr then
if fn then
log('write', addr, payload)
Threads: 16
(22.06.2022, 09:27)admin Wrote: Add logging to ON_MESSAGE to check that you are getting the data. Also do a full script restart the script via disable/enable.
if addr then
if fn then
nothing different is logged..
Code: * arg: 1
* arg: 2
* bool: true
* arg: 3
* number: 0
* arg: 4
* arg: 5
* number: 0
* arg: 6
* nil
Threads: 41
The same script works for me when sending messages from MQTT explorer. Do you have "Allow anonymous connection" enabled in MQTT broker configuration on LM? If not then you need to specify the login/password in the script.
Modify the script around line 45 by adding login_set call and restart it via disable/enable:
Code: mclient = require('mosquitto').new()
mclient:login_set('test', '123456')
Threads: 16
29.06.2022, 13:45
(This post was last modified: 30.06.2022, 08:21 by a455115.)
Hello admin!
I did it and my script is already working! I still didn't understand where the problem was. I returned the original settings to LM, I wrote the same script and it already works!
Thanks again for your help and time
Threads: 16
30.06.2022, 15:12
(This post was last modified: 30.06.2022, 15:14 by a455115.)
I have another problem. The value I take from shelly is string, how do I convert it so I can use it as int or bool? And is there a way to add all the shelly functions to a library and call them only by name and serial number?
Threads: 41
You can write a custom conversion function and add it to mqtt_to_object_conv table. What kind of string value is it?
Threads: 41
In case somebody else needs this, here's an example that logs all messages for all topics from the local broker. If anonymous access is disabled then remove the comment (--) from line 23 and set username and password as needed.
Code: broker = '127.0.0.1'
if res then
mclient:subscribe('#')
log('mqtt message', topic, payload)
-- mclient:login_set('test', '123456')
mclient:loop_forever()
os.sleep(1)
Threads: 16
(30.06.2022, 15:19)admin Wrote: You can write a custom conversion function and add it to mqtt_to_object_conv table. What kind of string value is it?
It returns me an On / Off value but as a string.
Threads: 41
Add before multiply function:
Code: function onofftobool(payload)
return tostring(payload):lower() == 'on'
Then modify mqtt_to_object_conv table:
Code: mqtt_to_object_conv = {
['shellies/shellyplug-s-D9AA39/relay/0'] = onofftobool,
