Threads: 17
If we set the protocol to DHCP, and no one is giving the IP to the device, what is the default IP?
Thank you!
Threads: 21
Press and hold reset button for 10 sec till LED will start flash red, device will have temporary IP 192.168.0.10 till next reboot.
Threads: 1
Is there any implementation or library of the KNXNetIP tunneling protocol to get and send data from an LogicMachine to several devices KNXNetIP like IPS/S 3.1.1?.
Threads: 41
LM can connect only to a single tunnelling interface. Use Routing if you need many-to-many connection.
