Comparing object names with Json list
Hi.
Is it possible to compare the names of the objets in LM with a newer Json file that i have exported and converted from ETS/KNX? And somehow get a print of every objects with wrong names in LM?
Kai-Roger
Put your JSON data into the script and run once. It will log all objects that are present in JSON but not in LM and objects that have mismatching names.
require('json')
data = [[
PUT_JSON_DATA_HERE
objects = json.decode(data).objects
for id, obj in pairs(objects) do
  id = tonumber(id)
  curr = grp.find(id)
  addr = buslib.decodega(id)
  if curr then
    if obj.name and curr.name ~= obj.name then
      log('name mismatch ' .. addr, curr.name, obj.name)
    log('missing object ' .. addr)
(06.04.2021, 06:23)admin Wrote: Put your JSON data into the script and run once. It will log all objects that are present in JSON but not in LM and objects that have mismatching names.
require('json')
data = [[
PUT_JSON_DATA_HERE
  id = tonumber(id)
  curr = grp.find(id)
  if curr then
Thank you
Kai-Roger
Worked like a charm. This makes updating group text really easy.
But is there a possbility to make the log not show unassigned Group addresses, like this
* string: missing object 25/2/165
Want only the * string: name mismatch 8/3/1
Thanks in advance Smile
Remove the relevant log call:
require('json')
data = [[
PUT_JSON_DATA_HERE
  id = tonumber(id)
  curr = grp.find(id)
  if curr and obj.name and curr.name ~= obj.name then
