Threads: 41
An update will be published next week
Threads: 17
(16.07.2021, 07:59)admin Wrote: An update will be published next week
Thank you for the update!
Threads: 17
I've installed the Zigbee update but the dimmer still hasn't the rgb+cct object available.
I rebooted LM, removed the zigbee dimmer from the list and re-added it, but no change.
Is there something I'm doing wrong?
Below the log from the zigbee dimmer aswell as the configuration view.
Code: 2021-07-19 22:15:34 ZB: packet from 84fd27fffe3b0fd5:
{ FrameControl = [ "FrameTypeGlobal", "DirectionFromServer", "DisableDefaultResponse" ], TransactionSequenceNumber = 2, GeneralCommandFrame = { CommandIdentifier = "ReportAttributes", ReportAttributes = { AttributeReports = [ { AttributeIdentifier = 0, Attribute = { Type = "uint8", Value = 0 } }, { AttributeIdentifier = 1, Attribute = { Type = "uint8", Value = 254 } } ] } } }
2021-07-19 22:15:34 CC: incoming message from F050, cluster 0300, dst EP 1
2021-07-19 22:15:34 CC: MT command AREQ_AF_INCOMING_MSG, payload:
{ LinkQuality = 21, Data = [ 24, 2, 10, 0, 0, 32, 0, 1, 0, 32, 254 ], SrcAddr = 61520, SecurityUse = 0, Radius = 29, ClusterId = 768, SrcEndpoint = 1, MacSrcAddr = 61520, GroupId = 0, TransSeqNumber = 0, Timestamp = 9105288, DstEndpoint = 1, WasBroadcast = 0 }
2021-07-19 22:15:34 CC: MT type AREQ (2), subsystem AF (0x04), command id 0x81, data:
[33] 44 81 00 00 00 03 50 F0 01 01 00 15 00 88 EF 8A 00 00 0B 18 02 0A 00 00 20 00 01 00 20 FE 50 F0 1D
2021-07-19 22:15:34 ZB: attribute report from 84fd27fffe3b0fd5:
{ onoff = true }
{ FrameControl = [ "FrameTypeGlobal", "DirectionFromServer", "DisableDefaultResponse" ], TransactionSequenceNumber = 1, GeneralCommandFrame = { CommandIdentifier = "ReportAttributes", ReportAttributes = { AttributeReports = [ { AttributeIdentifier = 0, Attribute = { Type = "bool", Value = true } } ] } } }
2021-07-19 22:15:34 CC: incoming message from F050, cluster 0006, dst EP 1
{ LinkQuality = 21, Data = [ 24, 1, 10, 0, 0, 16, 1 ], SrcAddr = 61520, SecurityUse = 0, Radius = 29, ClusterId = 6, SrcEndpoint = 1, MacSrcAddr = 61520, GroupId = 0, TransSeqNumber = 0, Timestamp = 9105272, DstEndpoint = 1, WasBroadcast = 0 }
[29] 44 81 00 00 06 00 50 F0 01 01 00 15 00 78 EF 8A 00 00 07 18 01 0A 00 00 10 01 50 F0 1D
2021-07-19 22:15:32 ZB: packet from 84fd27fffe3b0fd5:
{ FrameControl = [ "FrameTypeGlobal", "DirectionFromServer", "DisableDefaultResponse" ], TransactionSequenceNumber = 5, GeneralCommandFrame = { CommandIdentifier = "ReportAttributes", ReportAttributes = { AttributeReports = [ { AttributeIdentifier = 3, Attribute = { Type = "uint16", Value = 0 } }, { AttributeIdentifier = 4, Attribute = { Type = "uint16", Value = 0 } }, { AttributeIdentifier = 7, Attribute = { Type = "uint16", Value = 500 } } ] } } }
2021-07-19 22:15:32 CC: incoming message from F050, cluster 0300, dst EP 1
2021-07-19 22:15:32 CC: MT command AREQ_AF_INCOMING_MSG, payload:
{ LinkQuality = 21, Data = [ 24, 5, 10, 3, 0, 33, 0, 0, 4, 0, 33, 0, 0, 7, 0, 33, 244, 1 ], SrcAddr = 61520, SecurityUse = 0, Radius = 29, ClusterId = 768, SrcEndpoint = 1, MacSrcAddr = 61520, GroupId = 0, TransSeqNumber = 0, Timestamp = 9100402, DstEndpoint = 1, WasBroadcast = 0 }
2021-07-19 22:15:32 CC: MT type AREQ (2), subsystem AF (0x04), command id 0x81, data:
[40] 44 81 00 00 00 03 50 F0 01 01 00 15 00 72 DC 8A 00 00 12 18 05 0A 03 00 21 00 00 04 00 21 00 00 07 00 21 F4 01 50 F0 1D
2021-07-19 22:15:32 ZB: attribute report from 84fd27fffe3b0fd5:
{ level = 254 }
{ FrameControl = [ "FrameTypeGlobal", "DirectionFromServer", "DisableDefaultResponse" ], TransactionSequenceNumber = 4, GeneralCommandFrame = { CommandIdentifier = "ReportAttributes", ReportAttributes = { AttributeReports = [ { AttributeIdentifier = 0, Attribute = { Type = "uint8", Value = 254 } } ] } } }
2021-07-19 22:15:32 CC: incoming message from F050, cluster 0008, dst EP 1
{ LinkQuality = 21, Data = [ 24, 4, 10, 0, 0, 32, 254 ], SrcAddr = 61520, SecurityUse = 0, Radius = 29, ClusterId = 8, SrcEndpoint = 1, MacSrcAddr = 61520, GroupId = 0, TransSeqNumber = 0, Timestamp = 9100319, DstEndpoint = 1, WasBroadcast = 0 }
[29] 44 81 00 00 08 00 50 F0 01 01 00 15 00 1F DC 8A 00 00 07 18 04 0A 00 00 20 FE 50 F0 1D
2021-07-19 22:15:32 CC: MT command AREQ_ZDO_SRC_RTG_IND, payload:
{ RelayList = [ ], DstAddr = 61520 }
2021-07-19 22:15:32 CC: MT type AREQ (2), subsystem ZDO (0x05), command id 0xC4, data:
[5] 45 C4 50 F0 00
[5] 45 C4 50 F0 00
2021-07-19 22:15:32 CC: MT command SRSP_ZDO_EXT_ROUTE_DISC, payload:
{ Status = 0 }
2021-07-19 22:15:32 CC: MT type SRSP (3), subsystem ZDO (0x05), command id 0x45, data:
[3] 65 45 00
2021-07-19 22:15:32 ZNP: sending request:
[9] FE 04 25 45 FC FF 03 03 67
2021-07-19 22:15:32 SREQ: sending ZDO_EXT_ROUTE_DISC, data:
{ Radius = 3, DestinationAddress = 65532, Options = 3 }
2021-07-19 22:15:32 ZB: send many to one route request
2021-07-19 22:15:19 ZB: packet from 84fd27fffe3b0fd5:
2021-07-19 22:15:19 CC: incoming message from F050, cluster 0300, dst EP 1
2021-07-19 22:15:19 CC: MT command AREQ_AF_INCOMING_MSG, payload:
{ LinkQuality = 31, Data = [ 24, 5, 10, 3, 0, 33, 0, 0, 4, 0, 33, 0, 0, 7, 0, 33, 244, 1 ], SrcAddr = 61520, SecurityUse = 0, Radius = 28, ClusterId = 768, SrcEndpoint = 1, MacSrcAddr = 5556, GroupId = 0, TransSeqNumber = 0, Timestamp = 9058612, DstEndpoint = 1, WasBroadcast = 0 }
2021-07-19 22:15:19 CC: MT type AREQ (2), subsystem AF (0x04), command id 0x81, data:
[40] 44 81 00 00 00 03 50 F0 01 01 00 1F 00 34 39 8A 00 00 12 18 05 0A 03 00 21 00 00 04 00 21 00 00 07 00 21 F4 01 B4 15 1C
2021-07-19 22:15:19 ZB: attribute report from 84fd27fffe3b0fd5:
{ level = 254 }
2021-07-19 22:15:19 CC: incoming message from F050, cluster 0008, dst EP 1
{ LinkQuality = 28, Data = [ 24, 4, 10, 0, 0, 32, 254 ], SrcAddr = 61520, SecurityUse = 0, Radius = 28, ClusterId = 8, SrcEndpoint = 1, MacSrcAddr = 5556, GroupId = 0, TransSeqNumber = 0, Timestamp = 9058523, DstEndpoint = 1, WasBroadcast = 0 }
[29] 44 81 00 00 08 00 50 F0 01 01 00 1C 00 DB 38 8A 00 00 07 18 04 0A 00 00 20 FE B4 15 1C
2021-07-19 22:15:18 ZB: packet from 84fd27fffe3b0fd5:
2021-07-19 22:15:18 CC: incoming message from F050, cluster 0300, dst EP 1
2021-07-19 22:15:18 CC: MT command AREQ_AF_INCOMING_MSG, payload:
{ LinkQuality = 28, Data = [ 24, 2, 10, 0, 0, 32, 0, 1, 0, 32, 254 ], SrcAddr = 61520, SecurityUse = 0, Radius = 29, ClusterId = 768, SrcEndpoint = 1, MacSrcAddr = 61520, GroupId = 0, TransSeqNumber = 0, Timestamp = 9057348, DstEndpoint = 1, WasBroadcast = 0 }
2021-07-19 22:15:18 CC: MT type AREQ (2), subsystem AF (0x04), command id 0x81, data:
[33] 44 81 00 00 00 03 50 F0 01 01 00 1C 00 44 34 8A 00 00 0B 18 02 0A 00 00 20 00 01 00 20 FE 50 F0 1D
2021-07-19 22:15:18 ZB: attribute report from 84fd27fffe3b0fd5:
{ onoff = true }
2021-07-19 22:15:18 CC: incoming message from F050, cluster 0006, dst EP 1
{ LinkQuality = 28, Data = [ 24, 1, 10, 0, 0, 16, 1 ], SrcAddr = 61520, SecurityUse = 0, Radius = 29, ClusterId = 6, SrcEndpoint = 1, MacSrcAddr = 61520, GroupId = 0, TransSeqNumber = 0, Timestamp = 9057333, DstEndpoint = 1, WasBroadcast = 0 }
[29] 44 81 00 00 06 00 50 F0 01 01 00 1C 00 35 34 8A 00 00 07 18 01 0A 00 00 10 01 50 F0 1D
Threads: 41
That was a different update
Try updating now and see if it works for you.
Threads: 17
(20.07.2021, 13:09)admin Wrote: That was a different update
Oh, my sorry. I've updated and it's working purrrrrfect!
Thanks and thumbs up.
Threads: 3
Hi:
I have a Schneider Smart Zigbee Adapter dongle. Can I use it with LM Reactor 5 with the latest firmware installed?
Thanks in advance
Threads: 21
No you cant.
Threads: 6
any news on the official usb/zigbee adapter , the one with external antenna and more than 15 devices supported ???
Threads: 21
We have first prototypes and they do work great. To official sale it is still a while 2-3 months I think.
Threads: 34
Could you please add support of these devices:
- WXKG01LM (Xiaomi MiJia wireless switch)
- RTCGQ01LM (Xiaomi MiJia human body movement sensor)
- MCCGQ01LM (MiJia door & window contact sensor)
- MCCGQ11LM (Aqara door & window contact sensor)
Also it would be great if you can just copy all devices info from zigbee2mqtt.
Thanks in advance!
Threads: 41
Ok but it will take some time to implement. Our solution is different from zigbee2mqtt so their device database cannot be used directly.
Threads: 21
Hallo,
I own a LM5 MX.6cpu
Is there the possibility to earn a zigbee dongle implement zigbee network?
I'm actually using zigbee2mqtt, it works fine, but I do have another server... whitch is not my intention
thanks
Marco
Threads: 41
Which dongle are you using with zigbee2mqtt? If it's based on the CC2531 chip then it will work with LM. But please keep in mind that the current app is in beta state and the number of supported devices is limited.
Threads: 34
(15.09.2021, 12:56)Bitver Wrote: Could you please add support of these devices:
Thanks in advance!
When can I expect these devices to be added?
Threads: 41
Threads: 1
Hello!
How can I get the LM app?
Threads: 41
The app is published in our app store. On the main apps page click the plus icon in the top right corner.
Threads: 1
There is not this application, so I ask.
Threads: 41
Which hardware and firmware version do you have?
Threads: 1
Latest firmware. But I already consulted, I was told that this is not supported on LM4. It is not written about it anywhere. Thanks for the help.
