Threads: 41
@Bitver, I've had a look at Xiaomi devices and unfortunately all of them have non-standard behavior. It is quite to hard to add them without having an actual device to test. I can provide an example of how to monitor ZigBee messages via a script and implement your own actions based on this.
Threads: 7
Dear friends, I am just starting my ZigBee experience, looking for some water leak sensors and fire alarm sensors. What usb-device should I purchase to connect to Wiser for KNX? What sensors are good and easy to connect and control?
Thank you!!
Threads: 41
ZigBee is only supported in LM at the moment.
Threads: 7
05.10.2021, 07:52
(This post was last modified: 05.10.2021, 07:53 by alexgleyzer.)
Maybe I should go for LM instead of Wizer?)) How do I get it?
Threads: 21
(05.10.2021, 07:52)alexgleyzer Wrote: Maybe I should go for LM instead of Wizer?)) How do I get it?
Contact our office
https://openrb.com/contact-us/
Threads: 24
Today i tried some Elko Smartplugs, the on/off command works, but something strange with the feedbacks.
is this a bug or have i done something wrong in the setup?
there are 3 commands available:
On/off - Works perfectly
On/off Status - Does not work on GA, but works in Zigbee app
Active power - Does not work on GA and in Zigbee app
The Elko Smartplug is recognised as "Schneider Electric - SMARTPLUG/1" in the Zigbee app.
BR Even Sundgot.
Threads: 41
For status and active power management a profile should be added. Can you provide a screenshot of the device info (click "i" icon in the list)?
Status is a tricky topic in ZigBee. There's no standard algorithm so some devices might not send the status when you control them via ZigBee, only when a physical button is pressed. Certain lamps do not report color status at all. Some lamps/dimmers will report "off" state when level is set to 0 but others will not.
Threads: 21
SE iTRV is on our list, sooner or later will be added.
Threads: 21
It was removed by SE.
Threads: 24
Thats too bad, would have been nice to integrate powertags also.
