Threads: 60
Just did the same thing and it works. Try disabling the schedule and then saving the script and enabling it. Try rebooting the LM. Still not working after that then can only be firmware. If you working on the current beta, could try reinstalling the firmware.
Thanks,
Roger
Threads: 29
I use the actual release of spaceLYnk Firmware 1.2. On the other SL where the same script is working was made as there was installed the former firmware 1.1.1....
I think it must be a bug in my firmware :-( but what should I now doing.
reboot, deactivate reboot&storing the same script again, made a copy of them.... all didn't works...
Is there anything in Error logs?
Threads: 29
04.07.2016, 13:37
(This post was last modified: 04.07.2016, 13:37 by Habib.)
Hi admin,
no, but now it's working. After few reboots with the GUI Commend, now I've disconnected the power and after it cames back, the script excecute every 2 minutes :-)
But why I need a whole cold reboot for activating a scheduled script?
No, reboot is not needed and there's no difference between hot/cold boot. Try to reproduce this issue.
