Daikin VRV air conditioner controller DTA116A51
Hello.
I need to control VRV daikin DTA116A51 air conditioner via Mobus RS485 protocol with LM5 lite.
Who has the control floor, please give me data and configuration.
Thanks a lot.
.pdf   SDS-DTA116A51-Modbus-Adapter.pdf (Size: 538.39 KB / Downloads: 35)
This data sheet does not explain correctly what modbus function, registry addresses and datatype should be used.
Here is something done by another user https://forum.logicmachine.net/showthrea...7#pid15617
Bitmask writing is now possible so his problem would be solved in profile.
(03.08.2021, 09:43)Daniel. Wrote: This data sheet does not explain correctly what modbus function, registry addresses and datatype should be used.
Thank you very much.
