Threads: 85
Hi all,
any experience script about timer to manage an irrigation system with knx?
I have 10 irrigation valves which I control by knx. At starting time valves must open and closed step by step and when timer for one zone is expired start the followed zone.
The user must choose the working time for each valves and user can select which valves have to work.
What do you suggest?
Threads: 85
In order to simplify the question what is your idea to realize a countdown starting with a time insert by user?
Threads: 41
You can create a sequence with any number of outputs this way, just modify the parameters and object list to suit your needs:
Code: mintimer = 5 -- minimum timer value in seconds
maxtimer = 60 -- maximum timer value in seconds
objects = {
output = '1/1/1',
timer = '2/1/1',
output = '1/1/2',
timer = '2/1/2',
output = '1/1/3',
timer = '2/1/3',
function dosleep(obj)
local timer = grp.getvalue(obj)
timer = tonumber(timer)
if timer then
if timer < mintimer then
timer = mintimer
elseif timer > maxtimer then
timer = maxtimer
sleep(timer)
for _, item in ipairs(objects) do
grp.write(item.output, true)
dosleep(item.timer)
grp.write(item.output, false)
Threads: 85
(03.08.2016, 06:19)admin Wrote: You can create a sequence with any number of outputs this way, just modify the parameters and object list to suit your needs:
objects = {
output = '1/1/1',
timer = '2/1/1',
output = '1/1/2',
timer = '2/1/2',
output = '1/1/3',
timer = '2/1/3',
if timer then
timer = mintimer
timer = maxtimer
sleep(timer)
dosleep(item.timer)
Thank you but in case I would like to increase the time per zone? I mean that timer has to be from 1 minute to 30 minutes. How can I do that?
Threads: 41
If you're fine with having timer resolution in minutes not seconds, this should work:
Code: mintimer = 1 -- minimum timer value in minutes
maxtimer = 30 -- maximum timer value in minutes
objects = {
output = '1/1/1',
timer = '2/1/1',
output = '1/1/2',
timer = '2/1/2',
output = '1/1/3',
timer = '2/1/3',
if timer then
timer = mintimer
timer = maxtimer
sleep(timer * 60) -- minutes -> seconds
dosleep(item.timer)
Threads: 85
Hi admin,
I finally test it and it is work fine. What I would like to do is add, for every step an enable.
I mean that it enable object is =1 then system active the output for the time declared otherwise syste shift to the next step.
What lua instruction I could use?
Threads: 41
objects = {
output = '1/1/1',
timer = '2/1/1',
enable = '3/1/1',
output = '1/1/2',
timer = '2/1/2',
enable = '3/1/3',
output = '1/1/3',
timer = '2/1/3',
enable = '3/1/3',
if timer then
timer = mintimer
timer = maxtimer
if grp.getvalue(item.enable) then
dosleep(item.timer)
Threads: 2
Hi all
in case of needing to interrupt sequence (raining at that moment), how should we modify the code?
Threads: 41
Are you using a scheduled script for this?
Threads: 2
(12.03.2019, 07:35)admin Wrote: Are you using a scheduled script for this?
yes. but I need the sequence stops when it's raining to save water
Threads: 41
There's no built-in way to stop a scheduled script, but you can use this script (change script name to your scheduled script name):
Code: name = 'my script name'
item = script.get(name)
script.disable(name)
os.execute('pkill -f "scripting-scheduled.lua ' .. item.id .. '"')
You should also add sending 0 to all outputs.
Threads: 2
(12.03.2019, 08:30)Thanks!!. Works welladmin Wrote: There's no built-in way to stop a scheduled script, but you can use this script (change script name to your scheduled script name):
Threads: 2
Threads: 2
hi,
Is it possible to enable a delay on each of these timers?
I mean on the output:-)
Daniel
Threads: 53
(12.03.2019, 08:30)admin Wrote: There's no built-in way to stop a scheduled script, but you can use this script (change script name to your scheduled script name):
You should also add sending 0 to all outputs. Hi, I've found this script to stop an event scripting, I've tested but if the scripting is running it doesn't stop. Or better the led of status passes red and doesn't start in next event occured. Is It possible stop the event?
Best regards Cristian
Threads: 21
Threads: 53
Threads: 1
Hello!
How do I start this script at a certain time, selecting the days of the week? The selection will be made by the user.
Thank you!
Threads: 23
12.05.2022, 11:47
(This post was last modified: 12.05.2022, 11:53 by balatis.)
(11.05.2022, 11:42)costelservice@gmail.com Wrote: Hello!
Thank you!
Hi , you can creat a new object and on the new object creat a scheduler then remote irrigation script.
Code: [code]value = event.getvalue()
if value == true then
os.sleep(3)
grp.write("8/0/8",false)
if timer then
timer = mintimer
timer = maxtimer
os.sleep(timer *60 ) -- minutes -> seconds
mintimer = 0.1 -- minimum timer value in minutes
objects = {
output = '8/2/0',
timer = '33/5/8',
enable = '33/5/9',
dosleep(item.timer)
grp.write('8/1/0',false)
Threads: 3
I tried to use this script by event but there's no way to stop the script once started.
I used the script you suggested before but didn't work for me. I'm using a group address to trigger the event script with value 1 and would like to use the same group address with value 0 to stop the script. Do you know what could be happening? Thank you.
