Threads: 69
hello
I want to create a script that will trigger outputs if the current date and time matches the date and time in an array, array size will be 365*7
I have six-times columns for each day *365 days
for each column of the six columns a different output will be triggered.
what is the most efficient way to do this and which kind of scripts should I use?
Best Regards,
Threads: 41
Why don't you use schedulers for this?
Threads: 69
08.11.2021, 09:41
(This post was last modified: 08.11.2021, 09:43 by khalil.)
(08.11.2021, 09:36)admin Wrote: Why don't you use schedulers for this?
do you think that schedule is the best for this?
I think in scripts because it's more flexible and can be edited easily.
edit: Also because I have a lot of entries I think the script will be easy, I will get the table as excel instead of entering the data manually.
Best Regards,
Threads: 41
The question is where the schedule data comes from and if it should be editable by the end user. If the schedule is fixed then you can simply create a table with date/time and use a scheduled script that runs every minute to check if date/time matches.
Threads: 69
(08.11.2021, 09:45)admin Wrote: The question is where the schedule data comes from and if it should be editable by the end user. If the schedule is fixed then you can simply create a table with date/time and use a scheduled script that runs every minute to check if date/time matches.
thanks, admin
its a fixed date/time table
the date/time table represents the pray time for each day of the year.
I want to control the light and AC of the masjid (mosque) eg. turn on the light before azan time by x minutes if sunset.
I hope the description is clear now, what is your suggestion admin?
regards,
Best Regards,
Threads: 41
Scheduled script that runs every minute. Fill schedule table with dates and times.
Code: schedule = {
['1/1'] = { '1:05', '2:10' },
['12/31'] = { '1:11', '15:13' },
dtbl = os.date('*t')
date = string.format('%d/%d', dtbl.month, dtbl.day)
time = string.format('%d:%02d', dtbl.hour, dtbl.min)
schedtimes = schedule[ date ] or {}
for _, schedtime in ipairs(schedtimes) do
if schedtime == time then
-- execute action
I suppose there should be a formula for calculating times for each date. Might be easier to implement it instead of a fixed table.
Threads: 69
(08.11.2021, 13:19)admin Wrote: I suppose there should be a formula for calculating times for each date. Might be easier to implement it instead of a fixed table.
Thanks Admin
Yeah, there is a formula, but I didn't find the accurate one, so a fixed table will be an alternate way if I failed to find the accurate formula.
regards,
Best Regards,
Threads: 69
(08.11.2021, 13:19)admin Wrote: Scheduled script that runs every minute. Fill schedule table with dates and times.
Code: schedule = {
-- execute action
Hello Admin,
the Array will be defined every time the script Run? if yes how to define it once not run every cycle?
regards
Best Regards,
Threads: 41
Script runs every minute and checks if there's a matching date/time inside the schedule table. The schedule is defined once with all dates and times for the year. Put your actions after the "-- execute action" line. It will only be executed for matching date and time.
Threads: 69
13.11.2021, 11:23
(This post was last modified: 16.11.2021, 09:45 by khalil.)
Hello Admin
is there a chance that the schedule script miss the table time so the execution occurs before or after the desired time?
another question, I am trying to compare real time with the table time e.g. if nowTime (>,<,=) tableTime[Y] (+-) X then do something
Edit: This is what I did, any advice admin?
Code: dtbl = os.date('*t')
date = string.format('%d/%d', dtbl.day, dtbl.month)
timeNum = (dtbl.hour-y)*60 + (dtbl.min-x) -- current time in minutes
c = 0 -- to know active table time (active pray)
c=c+1
prayTimeAry = string.split(schedtime, ':')
prayNum = tonumber(prayTimeAry[1]*60) + tonumber(prayTimeAry[2])
if (prayNum - timeNum ) == 1 then ----edit
log ("amplifier CMD")
elseif schedtime == time then
log ('Azan CMD')
-- grp.write('1/0/37',true)
elseif (timeNum - prayNum) == 6 then
log("Turn OFF System")
Best Regards,
Threads: 41
It's very unlikely that the scheduled script will miss its execution. It would be better to use a formula and create scheduler events for the current day one per day.
Have you seen this Python script? Should be quite easy to rewrite it into Lua:
http://praytimes.org/code/git/?a=viewblo...aytimes.py
Threads: 69
(15.11.2021, 07:57)admin Wrote: It's very unlikely that the scheduled script will miss its execution. It would be better to use a formula and create scheduler events for the current day one per day.
thank you admin for your time,
I see such websites that used formula but in our region they used a table while there are several minutes different between the table and the formula (not in all days and not in all prays). So I will use the table because its the most reliable right now.
Best Regards,
