Threads: 37
Hi admin, any idea how to have GA from grp.tag for example:
var ids = [ '20/4/1','20/4/2' , '20/4/3' ];
instead of trend ID
var ids = [ 1, 3, 5 ];
SE ECO EXPERT
Threads: 41
Not possible without an .lp script to find matching trend IDs to the provided group addresses.
Threads: 37
25.03.2024, 08:54
(This post was last modified: 25.03.2024, 08:55 by domotiqa.)
ouch... that was what I was thinking.
I will maybe try to add script that put in comment of an object his trend id
there is no way in javacript to do sql query
SE ECO EXPERT
Threads: 41
I don't see any other solution but to use a .lp script.
Threads: 44
(14.03.2024, 07:31)admin Wrote: This function can be used to fetch trend data. Change ids array as needed.
Code: function getdate(offset) {
var date = new Date();
date.setDate(date.getDate() + offset);
var year = date.getFullYear();
var month = date.getMonth() + 1;
var day = date.getDate();
return { year, month, day };
function getdata() {
var data = JSON.stringify({
dates_curr: {
start: getdate(0),
end: getdate(1)
ids: ids,
$.post('/scada-vis/trends/fetch', { data }, function(trends) {
var result = [];
trends = JSON.parse(trends);
$.each(trends, function(_, trend) {
result.push(trend.data);
console.log(result);
Is it possible to get data timestamps using this code?
Threads: 41
Custom JS to fetch trend data from trends.lp:
var trends = [
1,
'Temperature',
'Humidity',
trends: trends,
dates: {
start: getdate(0),
end: getdate(1),
// resolution: 86400,
// timestamps: true,
$.post('/user/trends.lp', data, function(resp) {
console.log(resp);
Both trend ID and name can be specified. Set resolution to 86400 to fetch daily data. Set timestamps to true to fetch both data and timestamps.
trends.lp
Code: <?
require('json')
require('trends')
trends.NaN = json.null
ngx.header.content_type = 'application/json'
local req = ngx.req.get_body_data()
req = json.pdecode(req)
local res = {}
local dates = req.dates
local resolution = tonumber(req.resolution)
local timestamps = toboolean(req.timestamps)
for i, idname in ipairs(req.trends) do
local id = tonumber(idname)
if id then
res[ i ] = trends.fetchrangebyid(id, dates, resolution, timestamps)
res[ i ] = trends.fetch(idname, dates, resolution, timestamps)
json.write(res)
Note that there is no input data validation so the script can end with 500 Internal Server Error if the input data is incorrect.
Threads: 37
27.03.2024, 09:14
(This post was last modified: 27.03.2024, 09:31 by domotiqa.)
Thanks for your lp file.
I tried to do sum of the value, but can't get length value, still 0 for result. however I can see the result value as array type in console...
I tried lots of solution with each, for... without success. Any idea ?
Code: function readTrend( listeId, dayBefore, dayBase )
dates_curr: {
start: getdate(dayBefore),
end: getdate(dayBase)
ids: listeId,
var result = [];
var totVal=[];
return sum(result);
Code: function sum(array) {
//test each
let totVal = 0
console.log(array[1]);
let newArray=new Array();
newArray=array;
$.each(newArray, function(_, lined) {
console.log(lined.data);
// test for
for (let l = 0; l < array.length; l++) {
console.log('hello');
var sum = 0;
for (let k = 0; k < array[l].length; k++) {
sum += array[l][k];
//console.log(sum);
totVal.push(sum);
return sum(result);
result array in console log. Also result[0] or result[1] or result[0][0]...don't work.
Code: Array []
0: Array(24) [ 112, 112, 114, … ]
1: Array(24) [ 291, 173, 666, … ]
2: Array(24) [ 13, 14, 13, … ]
length: 3
<prototype>: Array []
scada-vis:771:11
only solution I found is using inside the function
Code: function readTrend( listeId, dayBefore, dayBase, total )
dates_curr: {
ids: listeId,
var result = [];
var totVal=[];
if (total>0) {
let totVal = 0
for (let l = 0; l < trend.data.length; l++) {
totVal += trend.data[l];
result.push(totVal);
} else {
return result;
However I can't understand why in the other solution the lenght and [x] don't work
SE ECO EXPERT
Threads: 37
I need help.
Not so good with Javascript...
I have this code:
date.setDate(date.getDate() + offset+1);
function getdata(nom, dayBefore, dayBase,total) {
var result = [];
var trendsName = [];
var trendsAddress = [];
var myJsonString='';
//FIND GA NAME AND ADDRESS
$.each(grp.tag(nom), function(id, object) {
trendsName.push(object.name);
trendsAddress.push(Scada.encodeGroupAddress(object.address));
// CREATE ARGUMENT
trends: trendsAddress,
dates: {
end: getdate(dayBase),
// TRENDS.LP POST
$.each(resp, function(id, object) {
// SUM TO TOTAL
if (total>0) {
let totVal = 0;
for (let l = 0; l < object.length; l++) {
totVal += object[l];
result.push(trendsName[id],totVal);
// NO TOTAL
} else {
result.push(trendsName[id],object);
return result;
My problem I can't iterate on the array on the function:
for example with
//last day
let day=getdata(classImage,-1,0,1);
this don't work. Lentgth return 0...
for (let i = 0; i < day .length; i++) {
console.log(day[i])
however a console.log of day show all result... and a length. I gess there is something with scope/timelaps but I try also in jquery, with map... all same.
Code: Array []
0: "PV - Active Energy No reset"
1: 16854
2: "General- Active Energy No reset"
3: 19329
length: 4
If our so nice admin could help me a bit, greatly appreciated.
SE ECO EXPERT
Threads: 41
Does the request to trends.lp return anything?
I suppose you need two arrays if you want to display the data in the chart - one with labels (trend names) another with the actual data.
Threads: 37
08.04.2024, 14:24
(This post was last modified: 08.04.2024, 14:54 by domotiqa.)
yes the right value.
It s just I can't iterate here for example:
console.log(day)
for (let l = 0; l < day.length; l++) {
console.log(day[l])
the console.log(day) return right value array with value, length...
if I console.log( day.length ) it say zero
and so the console.log(day[l]) never happen, I i log day.length it said zero.
I thing there is something with
Code: $.ajaxSetup({async:false}); //execute synchronously
I add it and it works....
https://stackoverflow.com/questions/9269...ost-jquery
SE ECO EXPERT
Threads: 4
Does anyone know how to integrate the legend in the Chartist pie like this exemple ?
Pie Chart
Threads: 41
Click "Show code" under the example and it will show the relevant code.
Threads: 4
(02.05.2024, 10:39)admin Wrote: Click "Show code" under the example and it will show the relevant code.
I tried like that, but I don't have the color in front of the legend like in the example
Code: $(function() {
var chart;
grp.listen('32/1/22', function(obj, type) {
var planid = 12;
var groups = ['32/2/19','32/2/21', '32/2/23','32/2/25','32/2/27','32/2/29','32/2/31','32/2/33','32/2/35','32/2/37','32/2/39','32/2/41'];
var labels = [];
var series = [];
for (var group of groups) {
var obj = grp.find(group);
console.log(group, obj);
labels.push(obj.name);
series.push(obj.value);
var data = {
labels: labels,
series: series
var options = {
width: '300px',
height: '300px',
donut: true,
donutWidth: 50,
donutSolid: true,
startAngle: 270,
showLabel: false
if (chart) {
chart.update(data);
} else {
var el = $('<div class="chart"></div>').css({
position: 'absolute',
top: '750px',
left: '1210px'
}).appendTo('#plan-' + planid);
chart = new Chartist.Pie('.chart', data, options);
// Ajout des légendes
var legendContainer = $('<div class="legend"></div>'); // Création du conteneur de légende
data.labels.forEach(function(label, index) {
legendContainer.append('<div><span class="dot" style="background-color: ' + chart.data.series[index].meta + '"></span>' + label + '</div>'); // Ajout de chaque élément de légende avec la couleur associée
el.append(legendContainer); // Ajout du conteneur de légende au graphique
}, true);
Threads: 41
A work-around trick is to use SVG with the same classes as the chart to display a color box next to the legend text:
Code: var legendContainer = $('<div class="legend"></div>'); // Création du conteneur de légende
var code = ('a').charCodeAt(0)
var letter = String.fromCharCode(index + code)
var svg = '<svg width="16" height="16" class="ct-series-' + letter + '"><rect width="16" height="16" class="ct-slice-pie" /></svg>'
legendContainer.append('<div>' + svg + ' ' + label +' </div>'); // Ajout de chaque élément de légende avec la couleur associée
Threads: 1
(03.05.2024, 08:31)admin Wrote: A work-around trick is to use SVG with the same classes as the chart to display a color box next to the legend text:
Thanks ADMIN you are a magician
