Threads: 69
Hello
I have RGBW light and I want to change the icon color based on the RGBW feedback color.
Icon could be like this:
best regards,
Best Regards,
Threads: 41
Set Additional classes to rgbw and add this to Custom JS:
Code: $(function(){
$('.rgbw').each(function(index, el) {
var $el = $(el);
var addr = $el.data('status-object');
$el.find('img').css('visibility', 'hidden');
grp.listen(addr, function(object) {
var value = object.value;
var r = ((value >> 24) & 0xFF) / 255;
var g = ((value >> 16) & 0xFF) / 255;
var b = ((value >> 8) & 0xFF) / 255;
var w = (value & 0xFF) / 255;
var a = 0.6 * (1 - (1 - w) * (1 - w));
var rgb = [
Math.round(((1 - a) * r + a) * 255),
Math.round(((1 - a) * g + a) * 255),
Math.round(((1 - a) * b + a) * 255)
$el.css('background', 'rgb(' + rgb.join(',') + ')');
Icon will be hidden, the square size will be the same as the icon size. RGBW value is converted to RGB.
Threads: 69
11.04.2022, 08:34
(This post was last modified: 11.04.2022, 08:36 by khalil.)
Thanks Admin
But how to deal with different RGB, RGBW data type: objects 3byte RGB, 4byte RGBW, 6byte DALI RGBW.
Also Could we change the background of a circle and other shapes?
Best Regards,
Threads: 41
This will work both 4 and 6 byte RGBW as well as RGB (use rgb class for it):
Code: $(function(){
var $el = $(el);
var r, g, b, w;
if (typeof value == 'object') {
r = (value.red || 0) / 255;
g = (value.green || 0) / 255;
b = (value.blue || 0) / 255;
w = (value.white || 0) / 255;
else {
var rgb = [
$('.rgb').each(function(index, el) {
var $el = $(el);
$el.css('background', Scada.getRgbHex(object.value));
Shape can be changed via CSS (this will produce a circle):
Code: .rgbw {
border-radius: 50%;
A more complex shape can be done via clip-path: https://developer.mozilla.org/en-US/docs.../clip-path
Threads: 69
Hello Admin
Is it possible to link the background color with Also the on/off Feedback?
While the DALI RGBW status color stay on its last value even when the unit is off.
Best Regards,
Threads: 41
This can be implemented via a separate virtual object and event script.
Threads: 69
(11.05.2022, 10:31)admin Wrote: This can be implemented via a separate virtual object and event script.
Thanks Admin
If you could share an example I will be thankful.
Best Regards,
Threads: 41
You will need two event scripts. When lamp status (1/1/1) is off then the color status (32/1/1) is black, otherwise color control (1/1/2) value is used.
1. DALI RGBW color object:
Code: on = grp.getvalue('1/1/1')
if on then
value = event.getvalue()
value = { red = 0, green = 0, blue = 0, white = 0 }
grp.checkupdate('32/1/1', value)
2. Lamp on/off object:
Code: on = event.getvalue()
if on then
value = grp.getvalue('1/1/2')
Threads: 69
Thanks admin for the hint
I will do it in one script using TAG.
But I noticed that grp.checkupdate/write doesn't work on DT8 color objects, I used that in a resident script and its keep updating each cycle.
Best Regards,
Threads: 41
Yes, there is a bug in checkwrite for complex data types that use table values. Only date and time types are checked correctly.
Threads: 69
(11.04.2022, 08:53)admin Wrote: This will work both 4 and 6 byte RGBW as well as RGB (use rgb class for it):
Code: $(function(){
var $el = $(el);
var r, g, b, w;
else {
var rgb = [
var $el = $(el);
Code: .rgbw {
border-radius: 50%;
Hello Admin
I try to add box-shadow to make the color glow, but how to make it right (depend on the color feedback)?
Best Regards,
Threads: 41
Use this, blur/spread radius (10px 10px) can be changed if needed:
Code: $(function(){
var $el = $(el);
var r, g, b, w;
else {
var rgb = [
var bg = 'rgb(' + rgb.join(',') + ')';
$el
.css('background', bg)
.css('box-shadow', '0 0 10px 10px ' + bg);
var $el = $(el);
var bg = Scada.getRgbHex(object.value);
$el
Threads: 69
Great
Thank you very much
Best Regards,
