Threads: 41
Thanks, unfortunately the log does not provide any useful info on why the disconnect happens. Have you tested it using wifi and mobile data on the phone? Is there any difference? Can you also try browser on the phone, not the app.
Threads: 6
I did a full restore, then I restored with the backup again. Then it worked out. Strange error..
Threads: 41
Do you have any other cloud accounts that you can try? Also try cloud in Safari in private mode.
Threads: 41
I think it's some kind of a networking issue. But just to be sure can you try accessing cloud using Firefox on your office PC?
Threads: 3
Hello. I have a problem of connection with cloud. When I log in on app it look that all function well,
the connection icon is green and it say connection OK, but the feedback is not real and I can't execute any command. If I login with xxx.ccc.vvv.bbb/apps/data/mosaic30/ it work correctly. After if I synchronize with the button apposite inxxx.ccc.vvv.bbb/apps/data/lmcloud/ the app function again. It's possible create resident script on LM to synchronize automatically the connection?
Best regards.
Fabio Rusconi
Threads: 41
Check that LM cloud is updated to the latest version. Post what you have in LM cloud app logs.
