Threads: 14
I found this Python script to control a Samsung Smart TV.
Can someone help me to modify this Python script to a Lua script?
Source: https://github.com/vrachieru/samsung-tv-.../remote.py
Thanks in advance.
Threads: 41
This API uses websocket/JSON. You can use this example as a starting point: https://forum.logicmachine.net/showthrea...1#pid16331
Threads: 14
(24.02.2023, 14:13)admin Wrote: This API uses websocket/JSON. You can use this example as a starting point: https://forum.logicmachine.net/showthrea...1#pid16331
Got this so far but i'm strugling with the payload. What's the correct way to send the commands?
Code: host = '192.168.126.54'
port = 8001
name = 'SamsungTvRemote'
if not client then
ws = require('user.websocket')
json = require('json')
url = 'ws://'..host..':'..port..'/api/v2/channels/samsung.remote.control?name='..name
client, err = ws.client('sync', 10)
res, err = client:connect(url)
log( res, err)
if res then
client:send(json.encode({
payload = [[
'method': 'ms.remote.control',
'params': {
'Cmd': 'Click',
'DataOfCmd': key,
'Option': 'false',
'TypeOfRemote': 'SendRemoteKey'
payload = [['KEY_VOLUP']]
log('connection failed: ' .. tostring(err))
client:close()
client = nil
data, _, _, opcode, err = client:receive()
if data then
data = json.pdecode(data)
if data then
log(data)
log('receive failed: ' .. tostring(err))
client:close()
client = nil
Threads: 53
(24.02.2023, 13:59)Joep Wrote: Hello,
Thanks in advance.
Hi Joep,
have you tried with API cloud?
best regards Cristian
Threads: 41
Try this:
port = 8001
b64 = require('encdec').base64enc
url = 'ws://' .. host .. ':' .. port .. '/api/v2/channels/samsung.remote.control?name=' .. b64(name)
if not res then
log('connection failed', err)
return
resp = json.pdecode(data)
if type(resp) ~= 'table' or resp.event ~= 'ms.channel.connect' then
log('invalid response', data, err)
client:close()
return
key = 'KEY_VOLUP'
payload = json.encode({
method = 'ms.remote.control',
params = {
Cmd = 'Click',
DataOfCmd = key,
Option = 'false',
TypeOfRemote = 'SendRemoteKey'
client:send(payload)
client:close()
Threads: 14
It's not working as i got an 'unautorized' reply. I know you first need to submit each remote control by a popup that appears a the the tv screen.
So for that i just tested with a basic url:
url = 'ws://' .. host .. ':' .. port .. '/api/v2/'
And then i got this response:
Samsung TV websocket 27.02.2023 14:08:28
* table:
["data"]
* table:
["clients"]
* table:
[1]
* table:
["isHost"]
* bool: false
["id"]
* string: f996fa65-4b22-4021-8f30-56df2da9a983
["attributes"]
* table:
["name"]
* userdata: NULL
["deviceName"]
* string: Smart Device
["connectTime"]
* number: 1677503304615
["id"]
["event"]
* string: ms.channel.connect
The same url http://192.168.126.54:8001/api/v2/ in the webbrowser is giving me more information back:
"device": {
"FrameTVSupport": "true",
"GamePadSupport": "true",
"ImeSyncedSupport": "true",
"OS": "Tizen",
"TokenAuthSupport": "true",
"VoiceSupport": "true",
"countryCode": "NL",
"description": "Samsung DTV RCR",
"developerIP": "0.0.0.0",
"developerMode": "0",
"duid": "uuid:ab728320-b477-48f8-9728-dee89aa3b37c",
"firmwareVersion": "Unknown",
"id": "uuid:ab728320-b477-48f8-9728-dee89aa3b37c",
"ip": "192.168.126.54",
"model": "18_KANTM2_FRAME",
"modelName": "UE43LS03N",
"name": "[TV] Samsung Frame Series (43)",
"networkType": "wired",
"resolution": "3840x2160",
"smartHubAgreement": "true",
"type": "Samsung SmartTV",
"udn": "uuid:ab728320-b477-48f8-9728-dee89aa3b37c",
"wifiMac": "64:1c:ae:e3:3b:af"
"isSupport": "{\"DMP_DRM_PLAYREADY\":\"false\",\"DMP_DRM_WIDEVINE\":\"false\",\"DMP_available\":\"true\",\"EDEN_available\":\"true\",\"FrameTVSupport\":\"true\",\"ImeSyncedSupport\":\"true\",\"TokenAuthSupport\":\"true\",\"remote_available\":\"true\",\"remote_fourDirections\":\"true\",\"remote_touchPad\":\"true\",\"remote_voiceControl\":\"true\"}\n",
"remote": "1.0",
"uri": "http://192.168.126.54:8001/api/v2/",
"version": "2.0.25"
Threads: 41
It seems that you need to send KEY_HOME first to get the access token. Then add this token to the query string for further calls: ...samsung.remote.control?name=NAME&token=TOKEN
Add another client:receive() after sending the key and log the results.
Threads: 14
(27.02.2023, 13:40)admin Wrote: It seems that you need to send KEY_HOME first to get the access token. Then add this token to the query string for further calls: ...samsung.remote.control?name=NAME&token=TOKEN
This is the script so far:
port = 8001
if not res then
return
log(resp)
client:close()
return
key = 'KEY_HOME'
params = {
Cmd = 'Click',
DataOfCmd = key,
Option = 'false',
log(resp)
client:close()
The result is this:
Samsung TV websocket 27.02.2023 15:54:54
* table:
["event"]
* string: ms.channel.unauthorized
* arg: 1
* string: invalid response
* arg: 2
* string: {"event":"ms.channel.unauthorized"}
* arg: 3
* nil
Threads: 41
Comment out this check before the key is sent and try again.
Threads: 14
(27.02.2023, 14:58)admin Wrote: Comment out this check before the key is sent and try again.
Sorry but i don't understand what you mean with ' Comment out this check '
Threads: 41
Add comments to this check:
Code: -- if type(resp) ~= 'table' or resp.event ~= 'ms.channel.connect' then
-- log('invalid response', data, err)
-- client:close()
-- return
-- end
Threads: 14
(27.02.2023, 15:49)admin Wrote: Add comments to this check:
-- client:close()
-- return
-- end
I have a working script now using wss over port 8002. Only issue is that the TV keeps asking to accept the connection and it seems the token is changing all the time as i got a new one so now and then while testing.
port = 8002
name = 'MyRemote'
token = 16687249
url = 'wss://' .. host .. ':' .. port .. '/api/v2/channels/samsung.remote.control?name=' .. b64(name) .. '&token=' .. token
key = 'KEY_MUTE'
params = {
Cmd = 'Click',
DataOfCmd = key,
Option = 'false',
log(resp)
client:close()
Threads: 5
Hi there,
I am in the same situation as Joep.
websocket library working and comunicating with Samsung IP, but each time i send a KEY command the TV send us a new Token string and ask us to confirm the device.
Anyone have improved this?
And the wol packet i tried several scripts to switch ON the TV without success.... any idea about?
Threads: 14
23.02.2024, 11:16
(This post was last modified: 23.02.2024, 11:17 by Joep.)
(23.02.2024, 11:00)j.martinez@t-ingeniamos.com Wrote: Hi there,
Here's a working WOL script. I just tested with my Samsung tv and it works. Also for my pc and i believe many other devices.
Code: function wol(mac)
local m = ''
for w in string.gmatch(mac, "[0-9A-Za-z][0-9A-Za-z]") do
m = m .. string.char(tonumber(w, 16))
local udp = require("socket").udp()
udp:settimeout(1)
udp:setoption("broadcast", true)
udp:sendto(string.char(0xff):rep(6) .. m:rep(16) , '255.255.255.255', 9)
wol('60:2D:BE:C3:4A:BC') -- MAC address of your device
Threads: 5
(23.02.2024, 11:16)Joep Wrote: (23.02.2024, 11:00)j.martinez@t-ingeniamos.com Wrote: Hi there,
local m = ''
udp:settimeout(1)
Thank you very much Joep. I will try it later.
