Threads: 69
hello dears,
I have few devices connected on Modbus 485 Port.
while this is the second time that all devices disconnected suddenly, but didn't reconnect until I repot the SL!
Why could this issue happened and how to avoid it?
Best Regards,
Threads: 21
Hard to say, check if anything else didn't try to use same port.
Threads: 69
22.03.2023, 09:13
(This post was last modified: 22.03.2023, 09:13 by khalil.)
its only for Modbus RTU via profiles no scripts
I think to make a script to restart the modbus port if this issue happened. but this is not the optimal solution
Best Regards,
Threads: 21
See this
https://forum.logicmachine.net/showthrea...9#pid28969
But you should try to find the core for the issue, first is to check for any error logs when this happens.
