Threads: 21
You are probably blocked by browser with simple auth, If your camera can provide authentication via url parameters then it should work. Otherwise the only doable solution is this
https://forum.logicmachine.net/showthrea...2#pid21072
Your camera should be able to provide jpeg snapshot
Threads: 21
yes jpeg only for this widget from the link I sent you.
Threads: 21
The Chrome screenshot, is it also from cloud or locally?
Threads: 21
To see it in cloud make sure to sync cloud app.
Threads: 21
This setup you have will work only via cloud, locally we just stream this link but the simple auth you use will be blocked via browser/app. In cloud it will work as we are sending the image there and no auth is needed apart of the one to the cloud.
For locally to work you will need user and password as part of the URL parameters, after the cgi-bin/
Threads: 21
Threads: 5
That is exactly what has been done.
I tried entered login and password before and after the IP address.
It opens in the browser, without prompting for input, through the cloud there is no request, no picture.
Maybe I can send to you IP address and you can check at your side?
Threads: 21
You can, i tested a local camera and it worked.
Threads: 5
Hello everyone,
Maybe someone could share with own experience, which cameras you were used in Mosaic, in order to decide which camera to buy. Authentication does not work correctly on my Dahua camera.
