Threads: 2
After SW upgrade I do not see 1-wire tab in LM settings.
I still have some 1-wire mapping working fine but can't find where it is stored now.
HW: LM5 Lite + Ext (i.MX6)
SW: 20230420
Best regards,
Kirill
Threads: 21
Since this hardware does not have 1-wire it is no longer present in this fw. You can install it manually from additional packages.
Threads: 2
Daniel, actually I have LM5 DW1 with 1-wire output.
Did I select a wrong firmware?
Threads: 21
Looks like as above you wrote this HW: LM5 Lite + Ext (i.MX6)
Threads: 2
Yes, it is misleading . Text above is copied from System Upgrade window .
The device itself has LM5p2-DW1 tag on it and 2 1-wire connections.
Threads: 21
Yes you are right, try installing fw again or the package manually, something seems broken.
Threads: 2
Thank you , which package you would recommend to install?
Threads: 21
Threads: 2
Thank you, it works. All the best!
