Threads: 18
I'm trying to organize my Objects a bit with giving them tags I can use in scripting or just to filter what I need to see.
All my objects in building "small" is called "Small - Living Room - Light 1 On/Off" I want to give that Object 4 tags (Small, Living Room, Light 1, On/Off).
If I use the Object filter and type "Small" and then Mass edit > Object properties > Field list > Tags and type in "Small" it works.
But if I then use the Object filter again and type in "Living Room" and click Mass edit > Object properties > Field list > Tags, then there is no text and if I write "Living Room" and click "Save" then it deletes everything but the new tag "Living Room".
Threads: 21
Some years ago I made this script, now would do it differently but still will work.
seperators = '.,_ =+'
-- Start address of objects (min: 0/0/1 = main/sub/address)
start_main = 0
start_sub = 0
start_address = 1
-- End address of objects (max: 31/7/255 = main/sub/address)
end_main = 15
end_sub = 7
end_address = 255
------------------------------------------ End Parameters ------------------------------------------
------------------------------ DON'T CHANGE ANYTHING UNDER THIS LINE -------------------------------
function split(source, delimiters)
local elements = {}
local pattern = '([^'..delimiters..']+)'
string.gsub(source, pattern, function(value) elements[#elements + 1] = value; end);
return elements
-- Calculate start address to DB format
start_objectaddress = ((start_main * 2048) + (start_sub * 256) + start_address)
-- Calculate end address to DB format
end_objectaddress = ((end_main * 2048) + (end_sub * 256) + end_address)
-- Get all objects from DB
all_objects = db:getall('SELECT address, name, tagcache FROM objects')
for _, object in ipairs(all_objects) do
-- Check if object is inside given range
if object.address >= start_objectaddress and object.address <= end_objectaddress then
currentrowaddress = object.address
myobject = grp.find(currentrowaddress)
nameTable = split(myobject.name, seperators) --spliting object string in to table
-- log(nameTable)
for _, tag in ipairs(nameTable) do
tagvalue = tag
-- Check if object tag already exists inside DB
current_object_tag = db:getall('SELECT object, tag FROM objecttags WHERE object = ' .. currentrowaddress .. ' AND tag = "' .. tagvalue .. '"')
object_tagcache = db:getone('SELECT tagcache FROM objects WHERE address = ' .. currentrowaddress .. '')
if #current_object_tag == 0 then
-- Add object to table objecttags
db:insert('objecttags', {object = currentrowaddress, tag = tagvalue, })
-- Check if object already has other tag values inside DB and add new values to tagcache
if object_tagcache == nil or object_tagcache == "" then
db:update('objects', { tagcache = tagvalue }, { address = currentrowaddress })
tag_string = "" .. object_tagcache .. ", " .. tagvalue .. ""
log(tag_string)
db:update('objects', { tagcache = tag_string }, { address = currentrowaddress })
script.disable(_SCRIPTNAME)
Threads: 18
Thanks alot, do I just add it to the common functions?
Threads: 21
No, you run this script once as a script, can be resident. Based on used separators it will auto generate tags from the object name.
