Threads: 33
Hello i have big significant problem with LM. Three days ago client LM was send to default. Every setup from Logicmachine app is gone... Just network setup and Zerotier setup stays same.
Logs are cleared also.....
Acces is just trough Zerotier.
What does it mean? Problem with SD card, network attack?
Thank you
Threads: 41
Which firmware version do you have?
Threads: 33
Hello, I have a LM with version 202112. and there have been several power outages and it has been completely erased. I have tried loading the latest existing backup and it is still the same. SD problem?
Threads: 21
Usually if it is SD card device is not working correctly, How old is it? Maybe it is read-only issue.
Threads: 21
Create a object, sync project data and reboot, see if it is still there.
Threads: 21
hm, then maybe your backup is empty or corrupted? Send me via PM and I will check it.
Threads: 21
Your DB file is corrupted in this backup. nothing we can do.
Threads: 21
You can use 7zip to extract whats left like icons/images. Nothing from DB.
