Threads: 16
hi everyone, please i need to connect two distance knx installation using ip protocol over internet. i have configured tzo ip router an its work properly in local network but when i try t make the same thing using vpn to connect over internet it doesn't work. please someone can help solve this
Threads: 21
Please describe the problem you trying to solve and which hardware are you using.
Threads: 21
Wiser will accept only IP routing, tunneling is no option for you as it can connect only to single router.
It might work via VPN,if you enable multicast via VPN and increase multicast TTL on all KNX/IP routers.
Also make sure you use local IP range in VPN as wiser blocks any KNX communication from public IPs.
