Threads: 85
Dear all,
I should installed LM app (by apk file) on a Hikvision touch panel which works with Android 11.
Have you any feedback of working on Android 11?
Could you send us apk file please?
Threads: 21
Threads: 85
Hi Daniel,
could you re send apk for Android please?
Threads: 21
Threads: 21
There are two apps, which one do you want?
Threads: 21
More info you can find here:
https://forum.logicmachine.net/showthread.php?tid=5220
In did this is brand new app and it will work only with firmware 2024+ The goal for us was to make the app as simple as possible for the end user. App will nicely jump between local and cloud connection. It will also detect if your LM is not available on local network then cloud connection will be used. Due to simplification only one LM can be assigned to the app.
Threads: 0
Dear all,
I should installed LM app (by apk file) on a Akuvox touch panel which works with Android 9.
Have you any feedback of working on Android 9?
Threads: 21
New LM Home app works only from Android 10 so the old one is here
https://we.tl/t-wHhlkypzaK
