LM Home app (Andrоid/iOS starter)
#41
thanks!
This is a new version of our LM Home app where we added ability to add more than one LM to the app.
To add more than one LM do a long press on LM Home app icon on your mobile and select Add LM. You will see new search window to select which LM should be added. If there is only one available then LM login page will be added.
If you use remove LM button then you will see screen with all added LMs and you will have to select the one to be removed.
Clear config will delete all LMs.
Please test and feedback is more than welcome
https://dl.openrb.com/misc/lmhome-20240507_3.apk
(07.05.2024, 13:09)Daniel Wrote: This is a new version of our LM Home app where we added ability to add more than one LM to the app.
Hi Daniel and thanks for your work. Before install new version is it better uninstall the before version?
Best regards Cristian
This is one of the feedback we need if old configuration was preserved after installing new over old.
(07.05.2024, 14:39)Daniel Wrote: This is one of the feedback we need if old configuration was preserved after installing new over old.
Because I 've tried to install without uninstall but Android says that it is impossible install. I wait for other users.
Did you install the original app from apk we posted or from Play Store?  This should work fine over the Play store version.
I think by apk not by play store. Tomorrow I'm in the office where I ' ve installed my LM so I can try to make more serious test.
@Daniel
If the app was download from play store, it is possible update.
If the app was installed by APK from the forum, it is impossible update unless you have uninstalled it first.
Tomorrow I will connect a new LM and I check the multi plants.
Thanks and best regards Cristian
New version with one bug fixed.
https://dl.openrb.com/misc/lmhome-20240508_4.apk
Thank Daniel !
I hope to have its latest update on Appstore and CHplay Smile
a customer of mine download "LM Home" app on his Iphone 12.
Unfortunately every time he close the app he has to insert login and password. How can sort it out please?
Br
He probably is using admin account which will not be remembered. The remember password has to be set in user settings.
(15.05.2024, 13:39)Daniel Wrote: He probably is using admin account which will not be remembered. The remember password has to be set in user settings.
Thank you Daniel but is not admin account.
(15.05.2024, 13:54)Daniel Wrote: The remember password has to be set in user settings.
Honestly no because I though it was demanded to the phone. Let me test please.
I have the same situation as you!
I also memorized the password, and used the user account, but it still happened
Which OS do you use?
hi, pro !
I used Android !
(16.05.2024, 09:19)phongvucba Wrote: hi, pro !
I used Android !
Which Android version, we tested from 10 to 14
I used Android !
I use samsung S22ultra, android version 14 Smile
