Threads: 6
Hi!
Please advice how to save some values to memory, to be able to restore them after power-loss and reboot?
Does values in storage saved? How to sync storage to disk?
Threads: 41
Storage and main database are saved to the SD card every 30 minutes. Normal reboot via UI performs saving before the system is restarted. If a power loss happens then the latest values might be lost. You should install a UPS if there are frequent power outages.
Threads: 41
You can do this manually from the main UI by clicking "Sync project data". Using this too often is not recommended as it can degrade the internal SD card quickly.
Threads: 6
Why? The default save interval is there for a reason…
