Threads: 57
Hi all,
I installed the v2.8.0 Schneider Electric firmware on a Wiser For KNX 2.
At startup I accepted to be in HTTPS, but since then it has been impossible to access remotely via @IP:port -> browser message "Https not secure" .
Can I switch back to http (via a system setting)?
Can I reinstall v2.8.0 on itself to switch back to http?
Thank you in advance for your assistance.
Have good evening.
Threads: 21
No need to install old firmware, you can change it in System-Services-HTTP Server
Threads: 21
Change language to EN and post again.
Threads: 57
excuse me...
System > Services > HTTP server > HTTPS Mode > HTTP and HTTPS enabled
Threads: 21
Yes this is corect.
Threads: 57
...correct but no result after rebooting the product !
Threads: 21
Clear browser cache or try different.
Threads: 57
I try this yet, but message is always "connexion refused"
Threads: 21
I'm working on 3.0.0 and it works there. BTW 2.8.0 has serious bug 2.8.3 fallowed short after.
Threads: 57
So, in "private navigation" it works fine. You'are write, it's a problem of browser cache.
Many thank's Daniel.
Still effective as usual !
