Threads: 5
I have a KCD device, I'm trying to read a DALI2 equipment.
It's possible ?
I set the 0.1 DALY GATEWAY (INTERNAL) ... But the scan DALI2 return 0 elements !
Threads: 41
What kind of device are you connecting? What DALI power supply is used?
Threads: 41
You need to use a DALI power supply with LM KCD.
Also note that all ballasts (even DALI2) are under the Devices tab, while DALI2 sensors are under the DALI2 tab. You need to run the scan in both tabs to detect all devices.
Threads: 5
Ok,
I'm using the Foxtron DALI power supply. The tridonic (light) driver is working but the other sensor is not detected.. any idea why ?
