Communication problem on KNX
I have set up a LM to use as BACnet GW and programming interface to KNX. The KNX is just one line with 12 PIR's and one DALI GW.
My problem is that from LM I am not able to download to the DALI GW, but can download to all PIR's and see telegrams in Group Monitor without any problem. If I connect a different interface to the bus, I can download to the DALI GW as well.
I am thinking, could it be that the DL of the DALI GW (MTN6725-0004) requires long frame, and the LM does not support this? I have upgraded the FW to 20240219, but that did not solve my problem.
Any ideas?
I just tried SpaceLogic KNX DALI Gateway Pro MTN6752-0101 and it worked fine. What version of ETS do you use?
