JS different reactions between 2.8.0 and 2.8.3
Hi all,
I writed this script to open a plan according to a user, and hiding menus if it is not an 'admin' one.
It works fine on a HW2 v2.8.0
It don't works on a SpaceLynk v2.8.3
// Dominique Barboyon (c) 19/03/2024
// opens a specific plan according to the user login and hides menus if it's not admin
// 19/03/2024 - v1.0
$(function(){
   var xhttp = new XMLHttpRequest();
   xhttp.onreadystatechange = function() {
      if (xhttp.readyState == 4 && xhttp.status == 200) {
         var res = xhttp.responseText;
         res = res.trim();
         var isuser = 0;
         if (typeof(res) !== "undefined" && res !== null){
            if (res == 'lota00'){
               showPlan(3);
               isuser = 1;
            if (res == 'lotb05'){
               showPlan(19);
               isuser = 1;
            if (res == 'admin_craft'){
               showPlan(21);
               isuser = 0;
            if (res == 'admin'){
               showPlan(21);
               isuser = 0;
            if (isuser == 1){
               $('.menu').hide();
               $('.layers').css('left', 0);
   xhttp.open("GET", "/user/user.lp", true);
   xhttp.send();
So, it seams I have to install "user.lp" on the user directory on my SpaceLynk.
As I can't acces viai FTP (security reason) to the SpaceLynk's customer, I want to try to create it via a Lua scritp as this :
local f = assert(io.open("user/user.lp", "w"))
f:write("<?", '\n')
f:write("require('apps')", '\n')
f:write("clientuser = request.username or 'anonymous'", '\n')
f:write("print(clientuser)", '\n')
f:write("?>", '\n')
f:close()
Question 1 : what is exactly the path ? "user/user.lp" for example.
Question 2 : Is it necessary to update access rights for user.lp to rw-rw-rw- ?
Thank's in advance !
You don't need .lp file for this, simply use Globals.user variable.
Perfect Admin, thank you.
