Threads: 102
Is it possible somehow to force a client to reload the visualisation page(s) after I make a change?
Thank you
Threads: 6
06.02.2017, 17:08
(This post was last modified: 06.02.2017, 17:10 by Erwin van der Zwart.)
Yes that is possible by custom javascript.
You need a event listener on a KNX object and a function to reload the client ( location.reload(); )
There is just 1 but... The client has to load the custom javascript first, so you have to reload them once after adding this, from then you can always force a client reload with your KNX object.
Can you do this or do i need to create a sample? (done this already on project so i must have it already somewhere)
Threads: 102
May you please provide me a sample?
Thank you
Threads: 102
Perfect. It works like a charm on both visualisations.
Thank you
Threads: 102
I've found a problem. This script crashes LM. In my case everytime. I don't know if it depends on number of clients or size of the visu. Would it be possible to add some random delay for better load balancing?
Thank you
Threads: 6
08.05.2018, 11:48
(This post was last modified: 08.05.2018, 11:49 by Erwin van der Zwart.)
This function runs client side and does nothing special other then refreshing the browser, same as pressing F5. When you press F5 on the client, do you see same issue? Are there errors in the browser console?
Threads: 41
How many active clients do you have?
