Threads: 3
Looks good. When will this visualisation become available on the LM5p-DW1?
Threads: 99
you can use it already now, it is called Mosaic. You should have it installed by default on your device.
Threads: 18
Looks very good, I have a question concerning the mosaic or this new APP is it possible to put different names for each lighting when we have several lighting for example on the Switch Widget ?
Thank you and still good work.
Gadjoken.
Threads: 16
Hi Edgars,
How can I put a clock like in the example picture? It won't let me add any widgets to Home. My other question is where to change the language from?
Clock is just a mock-up picture for an old version. Something similar might be possible with Custom CSS but we don't have any examples for this.
To show widgets on the main page you need to enable "Show widgets on the Main page" in Setting & themes and set this option in Appearance tab for each widget that you want to show there.
Language is set on the main apps page in the settings menu.
