Threads: 102
I have neither Dali nor 1-Wire in my LM5. Can I hide these tabs somehow?
Thank you
Threads: 6
03.04.2017, 22:14
(This post was last modified: 03.04.2017, 22:39 by Erwin van der Zwart.)
No you can't ... at least not without manipulating the core.css, i would not advice to do that ..
But why do you even want that ??? They are not on front-end, so you could just ignore them ...
Threads: 41
You can remove genohm-scada-dali/w1 packages from system config > system > packages
Threads: 6
04.04.2017, 06:33
(This post was last modified: 04.04.2017, 06:34 by Erwin van der Zwart.)
Yes offcource on LM you can do that (:
The removal of any tab is not possible for HL/SL users as we don't support the option to remove packages..
Threads: 102
Thank you for your reply. But I can't remove these packages because lm5ex depends on them.
No packages removed.
Collected errors:
* print_dependents_warning: Package genohm-scada-dali is depended upon by packages:
* print_dependents_warning: genohm-scada-lm5ex
* print_dependents_warning: These might cease to work if package genohm-scada-dali is removed.
Threads: 102
OK, thank you.
Dali and 1wire tab is not problem. The only reason I want to hide it is to do the installation site as simple as possible. Now I have to remember "There's not a Dali at the device".
