Modbus Goodwe - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Modbus Goodwe (/showthread.php?tid=5032) Pages:
RE: Modbus Goodwe - fleeceable - 24.10.2023 (24.10.2023, 09:57)Amelie Wrote: Thank you for your help. I appreciate it very much!You are welcome! I don't have access to that system any more and backup is not the latest unfortunately but if I remember correctly, solar panel values was calculated. I didn't found that on registers. Registers what I used to calculate solar power is marked on picture. If you need, I have similar calculation done for SolarEdge system. Let me know, I can share the code. With SOC I struggled as well. But I don't remember if I got that limit working before client started to modify his solar and backup system... I'm going to add information what I have. Maybe it helps, maybe not. It discharged down to 5% as well. Then I made script what checks battery % and writes 8 into 47511 if battery SOC is <10% + hysteresis. That gonna put battery into standby. Maybe you can also set charge/discharge power to 0. Then it should also hold battery percentage. Adding picture where you can see that if EMS Power Mode is 8 then solar gonna still charge battery but discharging is not happening. It gonna hold that 100% You may also want to check register 47000. Another model manual but I think inverter uses same logic - page 10 https://en.goodwe.com/Ftp/EN/Downloads/User%20Manual/GW_ES,%20SBP%203.0-6.0kW%20G2_User%20Manual-EN.pdf RE: Modbus Goodwe - Amelie - 27.10.2023 (24.10.2023, 19:57)fleeceable Wrote: You are welcome! Concerning, the charging and recharging of the battery, I send my question to the R&D Departement of Goodwe. If get a useful answer, I will post it so that everyone can use it. But, I'm not fully understanding how you calculate the energy flows. So,
But how make you then the distinction between the power from the battery and the power from the PV. I already looked at different registers, but I get values from which I can not tell what they are. I have also different modules from Smappee to measure the power of different appliances and circuits. But, unfortunaltly it can not measure the battery, since it is DC. |
