Unicode to ASCII conversion - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Unicode to ASCII conversion (/showthread.php?tid=101) |
Unicode to ASCII conversion - buuuudzik - 07.10.2015 Do you know how to convert Unicode to ASCII text? Or how to add Unicode text from variable(non group address) to visualization without conversion? RE: Unicode to ASCII conversion - admin - 07.10.2015 Visualization uses UTF-8 by default, as for dynamic text display you can use 255-byte string data type. It should work without any conversion. RE: Unicode to ASCII conversion - buuuudzik - 07.10.2015 (07.10.2015, 13:49)admin Wrote: Visualization uses UTF-8 by default, as for dynamic text display you can use 255-byte string data type. It should work without any conversion. Where is this type? RE: Unicode to ASCII conversion - admin - 08.10.2015 Take a look at the attached screenshot, you should set the datatype for object and you don't have to specify it when calling grp.write() or grp.update(). RE: Unicode to ASCII conversion - buuuudzik - 08.10.2015 (08.10.2015, 06:08)admin Wrote: Take a look at the attached screenshot, you should set the datatype for object and you don't have to specify it when calling grp.write() or grp.update(). It works Great job! |
