[Touch Visu] Customize Options? - Printable Version
+--- Thread: [Touch Visu] Customize Options? (/showthread.php?tid=1031)
[Touch Visu] Customize Options? - Habib - 08.10.2017
I've searched in the forum for such solutions which are already posted, but I found only the option to hide the Menu (which works well).
Now I need to limit the rows to one and maybe if it's possible to scale all sizes a little bit up.
Is this possible?
RE: [Touch Visu] Customize Options? - admin - 10.10.2017
Use this for single column display:
.touch .control-item {   float: none;   width: 100%;   border-right: none; } .touch .control-item:nth-child(2) {   border-top: 1px solid #ddd;   height: 49px; } .touch .control-item-pad {   display: none; }
You can try this for scaling, but this might not work on all devices:
.touch {   width: 80%;   height: 80%;   transform: scale(1.25);   transform-origin: 0 0; } .container {   min-width: 150px; }
