email setting - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: email setting (/showthread.php?tid=1036) Pages:
email setting - gkentsis - 10.10.2017 Hi our smtp server needs to enable tls. what is the right parameter for secure? txs RE: email setting - admin - 10.10.2017 Put tlsv12 there, but in most cases port 587 uses STARTTLS mode, so you need to install updated LuaSocket package. Which hardware are you using? RE: email setting - gkentsis - 10.10.2017 (10.10.2017, 12:24)admin Wrote: Put tlsv12 there, but in most cases port 587 uses STARTTLS mode, so you need to install updated LuaSocket package. Which hardware are you using? I have 1 LM4 and 1 LM5 with last firmware and with luashocket 2.0.2-17 both. My smtp server setting are So do i need to install LuaSocket package? RE: email setting - admin - 11.10.2017 Update package from System config-> System > Packages > Click (+) icon Package for LM4: https://dl.openrb.com/lm-17/pkg/luasocket_2.0.2-23_mxs.ipk Package for LM5: https://dl.openrb.com/lm-17-imx6/pkg/luasocket_2.0.2-23_imx6.ipk First try with secure = 'starttls', If it does not work then try secure = 'tlsv12', In your script put mail function call inside log( ) so you can see an error message in logs if there is any. RE: email setting - gkentsis - 11.10.2017 (11.10.2017, 07:59)admin Wrote: Update package from System config-> System > Packages > Click (+) icon hi with secure = 'starttls' email() returns * arg: 1 * nil * arg: 2 * nil and with secure = 'tlsv12' * arg: 1 * nil * arg: 2 * string: closed RE: email setting - admin - 11.10.2017 Can you send login/password that your are using via PM so I can check it locally? RE: email setting - gkentsis - 13.10.2017 (11.10.2017, 10:27)admin Wrote: Can you send login/password that your are using via PM so I can check it locally? sent it RE: email setting - admin - 13.10.2017 Thanks, please update packages again: Package for LM4: https://dl.openrb.com/lm-17/pkg/luasocket_2.0.2-23_mxs.ipk Package for LM5: https://dl.openrb.com/lm-17-imx6/pkg/luasocket_2.0.2-23_imx6.ipk Replace mail() function in Common functions with this and change from/user/password field values to your access details: Code: function mail(to, subject, message)
-- make sure these settings are correct
local settings = {
from = '...',
-- smtp username
user = '...',
-- smtp password
password = '...',
-- smtp server
server = 'mailgate.cosmotemail.gr',
-- smtp server port
port = 587,
-- enable tls
secure = 'tlsv1',
-- use STARTTLS mode
starttls = true,
local smtp = require('socket.smtp')
if type(to) ~= 'table' then
to = { to }
for index, email in ipairs(to) do
to[ index ] = '<' .. tostring(email) .. '>'
-- fixup from field
local from = '<' .. tostring(settings.from) .. '>'
-- message headers and body
settings.source = smtp.message({
headers = {
to = table.concat(to, ', '),
subject = subject,
['From'] = from,
['Content-type'] = 'text/html; charset=utf-8',
body = message
settings.from = from
settings.rcpt = to
return smtp.send(settings)
endRE: email setting - gkentsis - 13.10.2017 (13.10.2017, 08:45)admin Wrote: Thanks, please update packages again: it works perfect. Thank you very much Can you send me the package for LogicMachine5 Lite Power? RE: email setting - admin - 13.10.2017 It's already there: https://dl.openrb.com/lm-17-imx6/pkg/luasocket_2.0.2-23_imx6.ipk RE: email setting - Mrinj - 17.11.2017 Hi, Do I need LuaSocket package for HomelYnk also? Where can I find it? Can I use the same user script with my u/p server settings? Best, RE: email setting - Mrinj - 18.11.2017 Hi again, Just wanted to share that I found a solution for my question form this link: https://www.schneider-electric.com/en/download/document/AN011_SL/ Best, RE: email setting - Clémentine - 21.11.2017 Hi all, Can you help me to find the mistake in my script ? Thanks function Email(to, subject, message) -- make sure these settings are correct ---------------BEGINNING OF USER EDITABLE AREA------------------- local settings = { -- "from" field, only e-mail must be specified here from = 'bouvet.clementine@gmail.com', -- smtp username user = 'bouvet.clementine@gmail.com', -- smtp password password = 'xxxxx', -- smtp server server = 'smtp.gmail.com', -- smtp server port port = 465, -- enable ssl, required for gmail smtp secure = 'sslv23', } -------------------END OF USER EDITABLE AREA--------------------- local smtp = require('socket.smtp') local escape = function(v) return '<' .. tostring(v) .. '>' end -- message headers and body settings.source = smtp.message({ headers = { to = escape(to), subject = subject, }, body = message }) -- fixup from field settings.from = escape(settings.from) settings.rcpt = { escape(to) } return smtp.send(settings) end RE: email setting - admin - 22.11.2017 There's no point in using another function, you can just use mail(to, subject, message) from common functions. You should also wrap mail function call with log(mail(...)) to see the mail server response which might contain an error of some sort. RE: email setting - joaodaniel.pereira - 27.03.2024 Hi, What is wrong ? Code: -- user function library
local settings = {
from = 'XXXXXX@XXXXXX.COM',
-- smtp username
user = 'XXXXXX@XXXXXX.COM',
-- smtp password
password = 'XXXXXX',
-- smtp server
server = 'smtp.office365.com',
-- smtp server port
port = 587,
-- enable tls
secure = 'tlsv1.3',
starttls = true
to = { to }
-- fixup from field
headers = {
subject = subject,
['From'] = from,
body = message
settings.rcpt = to
log("send email:")
log(settings)
endRE: email setting - admin - 27.03.2024 Log what the mail function returns as suggested here: https://forum.logicmachine.net/showthread.php?tid=5242&pid=33911#pid33911 RE: email setting - joaodaniel.pereira - 27.03.2024 (27.03.2024, 09:29)admin Wrote: Log what the mail function returns as suggested here: https://forum.logicmachine.net/showthread.php?tid=5242&pid=33911#pid33911 initscript 27.03.2024 09:44:38 * arg: 1 * nil * arg: 2 * string: timeout to: server = 'smtp.office365.com', -- smtp server port port = 587, -- enable tls secure = 'tlsv1_3', -- use STARTTLS mode starttls = true,
RE: email setting - Daniel - 27.03.2024 Check this https://forum.logicmachine.net/showthread.php?tid=4714&pid=30472#pid30472 RE: email setting - Supersoon - 09.05.2024 (27.03.2024, 09:47)joaodaniel.pereira Wrote:(27.03.2024, 09:29)admin Wrote: Log what the mail function returns as suggested here: https://forum.logicmachine.net/showthread.php?tid=5242&pid=33911#pid33911 Hi, Did you managed to find the correct settings? I'm also trying to send an email via the same smtp server :-) and getting the following error: * arg: 1 * number: 1 * arg: 2 * nil Thanks! Niels RE: email setting - admin - 09.05.2024 What you are getting is not an error but a normal result: first return value is 1 = ok, second is nil = no error. |
