Custom values - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Custom values (/showthread.php?tid=106) |
Custom values - Logic - 17.10.2015 Hey In the visualization, I create objects and connect them to a group address. Occasionally, I want to put to use "Display mode: Value" e.g. when I want to see with text if something is on/off, day/time, etc. My question is, how do you use your own custom values instead of "on/off" or "monday/tuesday.."? The visualization I am making is in another language and I would prefer to not mix it up with English everywhere. Any ideas? RE: Custom values - Erwin van der Zwart - 18.10.2015 Hi Logic, On the object tab, click on the custom values icon of the object (the icon left of delete) to enter them. BR, Erwin RE: Custom values - Logic - 18.10.2015 Thanks Erwin That solves it for on/off objects. Apparently it does not work for things like the weekdays in 3 byte time/day objects. Error message says "custom values can only be set for boolean and integer datatypes". I tried to script my way out of the weekday problem, but the datatype only contains the digit for the day e.g. 1 for monday. RE: Custom values - Erwin van der Zwart - 18.10.2015 Hi Logic, Language of date and time is automaticly set by the selected language in the configuration part. Is the language you need not available there? BR, Erwin RE: Custom values - Logic - 19.10.2015 In the upper right corner, just left of "Start page" button in the logic machine, there are only two options and they are English and Russian. Also, on the start page there is some customization where four languages can be selected, English, French, German, Russian. The language I need is none of them. RE: Custom values - edgars - 21.10.2015 we will release soon update package which will contain all languages we have for LM |
