Modbus Mapper refresh not working - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Modbus Mapper refresh not working (/showthread.php?tid=1084) |
Modbus Mapper refresh not working - joost001 - 09.11.2017 I'm experiencing a problem with the Modbus mapper and my SMA inverter. I have been able to load a correct profile for 1 register and map it to a knx object. Poll interval is set at 10seconds. I see that the KNX object is correctly updated a first time. However, any changes afterwards are not refreshed in the KNX object. Is there anything else that I would need to investigate? If I remove the mapping and create a new one, the value gets written again only once. Anybody any clue? regards, Joost RE: Modbus Mapper refresh not working - admin - 09.11.2017 Post your profile and also check if there are entries in Error log. RE: Modbus Mapper refresh not working - joost001 - 09.11.2017 Hi Admin, I found the issue. the inverter still had a DHCP address which actually changed during my tests. as a result the modbus tcp connection failed. With a fixed IP the problem is resolved. I will post my full sma profile once I added the other registers (currently only defined 1 for test). regards, Joost RE: Modbus Mapper refresh not working - Domoticatorino - 14.01.2019 Hi, I wrote here because I have the same problem. I am usign RTU Modbus system. Profile is the one below: { "manufacturer":"France Air", "description":"Ventilazione Meccanizzata", "mapping":[ {"name":"System Power","bus_datatype":"1","datatype":"bool","type":"coil","address":0,"writable":true}, {"name":"Boost","bus_datatype":"1","datatype":"bool","type":"coil","address":9,"writable":true}, {"name":"Temperatura Air Fresh","bus_datatype":"9","datatype":"int16","type":"register","address":529,"writable":"false"}, {"name":"Temperatura Air Return","bus_datatype":"9","datatype":"int16","type":"register","address":530,"writable":"false"}, {"name":"Temperatura Air Supply","bus_datatype":"9","datatype":"int16","type":"register","address":531,"writable":"false"}, {"name":"Velocità","bus_datatype":"8","datatype":"uint16","type":"register","address":779,"writable":"true"}, {"name":"Temperatura Air Exhaust","bus_datatype":"9","datatype":"int16","type":"register","address":532,"writable":"false"} ] } Everything is fine the first time when I set the profile then it seems data are not refreshed. In Error log there is nothing about modbus. When I test the RTU reading variable is good. Any suggestion? Thanks. [attachment=1184 Wrote:Domoticatorino pid='11456' dateline='1547484820']Hi, Sorry but in Modbus Error Log system send the message enclosed. Thank you for your help. BR RE: Modbus Mapper refresh not working - Domoticatorino - 16.01.2019 Ok, problem solved. Being an Homelynk by Schneider, support sent me update patch need for the last firmware 2.3. Thanks BR |
