KNX read misc values from switch with script - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: KNX read misc values from switch with script (/showthread.php?tid=1086) |
KNX read misc values from switch with script - 02dag - 11.11.2017 I am wondering if it is possible to read different values from a switch. As an example I have a switch with thermostat(GIRA 514200). I would like to know if it is possible to read out values from this? I am interested in setpoint and actual temperature and operating mode The reason for this is because every once in a while the temperature or operating mode changes on some of the switches in my house. Other members of the household deny that it is their fault e.g pressing the wrong buttons when they are turning off the lights. RE: KNX read misc values from switch with script - Jørn - 11.11.2017 The objects has to be linked to group adresses, if this has not been done theres in nothing you can do from the LM. Are there not created groups for this in the project, do you use ETS yourself`? RE: KNX read misc values from switch with script - Erwin van der Zwart - 12.11.2017 Hi, When the objects are asigned to a group address inside the ETS, then the read flag must also been set on the object to be able to read the object value from the (any) controller. When all of the above is correct you can execute a grp.read(address) to request the current value from the object(s). BR, Erwin RE: KNX read misc values from switch with script - 02dag - 15.11.2017 (12.11.2017, 11:12)Erwin van der Zwart Wrote: Hi, This has not been done in my house. I have not yet received any ets-file from my electrician. On the other hand I have found out what was wrong with the switch. It happened that the location where the switch is placed is hit by direct sunlight, meaning that the measured temperature is increased until the switch resets itself and the default temp is set. Looking into this now. |
