LM as webserver - ERR_INVALID_HTTP_RESPONSE - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: LM as webserver - ERR_INVALID_HTTP_RESPONSE (/showthread.php?tid=1096) |
LM as webserver - ERR_INVALID_HTTP_RESPONSE - gjniewenhuijse - 20.11.2017 I have an "old" piece of code that generates a html response for clients that connects to my lm: http://192.168.x.x:19001/getdata/test Results: Chrome : ERR_INVALID_HTTP_RESPONSE IOS Safari : cancelling load from .... because it is using HTTP/0.9 Internet explorer and Edge works great. Anyone a solution? Code: -- init server handler
if not ready then
require('copas')
-- list of client sockets
clients = {}
-- incoming data handler
function datahandler(sock, data)
local ip, port
ip, port = sock:getpeername()
-- send reply
if string.find(data,"GET /getdata/test") then
sock:send(htmlbody)
--else
--log(string.format('[server] data from %s:%d - %s', ip, port, data))
-- connection handler
function connhandler(sock)
-- enable keep-alive to check for disconnect events
--sock:setoption('keepalive', false)
local ip, port, data, err, id
-- get ip and port from socket
-- client id
id = string.format('%s:%d', ip, port)
--log(string.format('[server] connection from %s', id))
-- save socket reference
clients[ id ] = sock
-- main reader loop
while true do
-- wait for single line of data (until \n, \r is ignored)
data, err = copas.receive(sock, '*l')
-- error while receiving
if err then
--log(string.format('[server] closed connection from %s:%d', ip, port))
-- remove socket reference
clients[ id ] = nil
return
-- handle data frame
if data == "" then
--log("stop")
break
-- bind to port 10001
tcpserver = socket.bind('*', 19001)
-- error while binding, try again later
if not tcpserver then
os.sleep(5)
log('[server] error: cannot bind')
-- set server connection handler
copas.addserver(tcpserver, connhandler)
-- create udp server on port 10002
udpserver = socket.udp()
udpserver:setsockname('*', 19002)
udpserver:settimeout(0.1)
ready = true
-- perform server tasks for one second (5 x (0.1 + 0.1))
for i = 1, 5 do
message = udpserver:receive()
-- got message from udp, send to all active clients
if message then
--log("message: " .. message .. " : " .. chartobyte(message))
for id, sock in pairs(clients) do
--log("client id: " .. id)
sock:send(message .. '\r')
copas.step(0.1)
-- all dynamic pages
htmlbody =
"<HTML>\n"..
"\n"..
"<HEAD>\n"..
"<title>Web Communication</title>\n"..
"</HEAD>\n"..
"\n"..
"<BODY>\n"..
"Web Communication \n"..
"<h3>Test</h3>\n"..
"<pre style='white-space:normal;'>"..
"</pre>"..
"<br>"..
"</BODY>\n"..
"\n"..
"</HTML>"RE: LM as webserver - ERR_INVALID_HTTP_RESPONSE - admin - 20.11.2017 Have you considered using .lp scripts with the main web server, or is the URL fixed on clients? RE: LM as webserver - ERR_INVALID_HTTP_RESPONSE - gjniewenhuijse - 20.11.2017 (20.11.2017, 10:47)admin Wrote: Have you considered using .lp scripts with the main web server, or is the URL fixed on clients? Its a fixed url RE: LM as webserver - ERR_INVALID_HTTP_RESPONSE - gjniewenhuijse - 21.11.2017 Can i change something to have working code? RE: LM as webserver - ERR_INVALID_HTTP_RESPONSE - admin - 21.11.2017 This should work. Another thing is that you probably don't need local UDP server here. If you want to send some dynamic data you can use storage. Code: -- init server handler
if not ready then
require('copas')
htmlbody =
"<html>\n"..
"\n"..
"<head>\n"..
"</head>\n"..
"\n"..
"<body>\n"..
"<h3>Test</h3>\n"..
"</pre>"..
"<br>"..
"</body>\n"..
"\n"..
"</html>"
function httpsend(sock, body)
local resp = 'HTTP/1.1 200 OK\r\nContent-Length: %d\r\nContent-type: text/html\r\nConnection: close\r\n\r\n%s'
local data = string.format(resp, #body, body)
return sock:send(data)
clients = {}
local ip, port
-- send reply
httpsend(sock, htmlbody)
--else
-- client id
-- main reader loop
while true do
if err then
clients[ id ] = nil
return
if data == "" then
--log("stop")
break
os.sleep(5)
ready = true
for i = 1, 5 do
if message then
copas.step(0.1)
endRE: LM as webserver - ERR_INVALID_HTTP_RESPONSE - gjniewenhuijse - 21.11.2017 thanks |
