Modbus IP problem - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Modbus IP problem (/showthread.php?tid=1143) |
Modbus IP problem - josep - 20.12.2017 Hello, I have an installation with a Seneca Modbut RTU to Modbus IP converter and I try to comunicate it with LM5, In Seneca module I can read modbus RTU variables perfectly but when I try to read this via LM5 only works with some values... In the other values appears a error log like that: "Invalid Data Adress" and I don't know what's the problem, THX. RE: Modbus IP problem - Erwin van der Zwart - 20.12.2017 Hi, Did you try to -1 the registers (if register = 2000 => use 1999 in the script to read it), this is most of the time the reason .. BR, Erwin |
