User specific default window - Printable Version
+--- Thread: User specific default window (/showthread.php?tid=1145)
User specific default window - Thomas - 20.12.2017
Hello
Have you found any way how to make a window default for a specific user?
What I want to do is: Employees works in their offices. If an employee opens the visualization he wants to see his own office at first screen.
Simple re-sorting of Windows is not an option because I want  tree structure based on buildings and floors and some employees share more than one room or use common spaces etc.
Any ideas?
Thank you.
RE: User specific default window - Erwin van der Zwart - 20.12.2017
You can fetch his/her login username and showPlan(x) based on username with custom JavaScript.
Put this in a file called user.lp inside your ftp user folder:
<?   require('apps')   clientuser = request.username or 'anonymous'   print(clientuser) ?>
Put this in your custom JS:
$(function(){   var xhttp = new XMLHttpRequest();   xhttp.onreadystatechange = function() {      if (xhttp.readyState == 4 && xhttp.status == 200) {         var res = xhttp.responseText;          res = res.trim();          if (typeof(res) !== "undefined" && res !== null){             if (res == 'erwin'){                showPlan(1);             }             if (res == 'admin'){                showPlan(2);             }          }      }   };   xhttp.open("GET", "/user/user.lp", true);   xhttp.send(); });
RE: User specific default window - Thomas - 21.12.2017
Super! Thank you
