Factory reset LM5 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Factory reset LM5 (/showthread.php?tid=1170) |
Factory reset LM5 - KingCanute - 08.01.2018 Is there a way to factory reset an LM5 without logging in? I'm sure what has happened to it, I can't reach on web from the IP adress I used for it. The adress is static, but it won't respond the trying to login to it. Is it possible that the internal SD card is faulty? RE: Factory reset LM5 - AEK - 09.01.2018 (08.01.2018, 18:44)KingCanute Wrote: Is there a way to factory reset an LM5 without logging in? I'm sure what has happened to it, I can't reach on web from the IP adress I used for it. The adress is static, but it won't respond the trying to login to it. Hi, if you have phisical access to LM you can use reset button. hold it for 10 seconds (until red Led start blinking) - it will reset IP settings to 192.168.0.10 (project settings will be kept) if you still have no access. press button once again for 10 seconds - it will do full factory reset Factory reset LM5 - KingCanute - 09.01.2018 I took out the SD card inside the LM5, and put it in my pc, but I can't read it. Is it readable with a pc, or does this mean it's broken and need to be replaced? I will try to reset it back to factory default just in case. Sent fra min SM-N950F via Tapatalk RE: Factory reset LM5 - AEK - 09.01.2018 (09.01.2018, 07:00)KingCanute Wrote: I took out the SD card inside the LM5, and put it in my pc, but I can't read it. Is it readable with a pc, or does this mean it's broken and need to be replaced? It is readable with a Linux pc, not Windows. yo can reflash sd card if factoory reset will not help you. use this page http://openrb.com/reflash-logicmachine3-and-streaming-player-software/ Factory reset LM5 - KingCanute - 09.01.2018 Which version of the firmware is for my model? I can't figure out which version I got. ![]() ![]() Sent fra min SM-N950F via Tapatalk RE: Factory reset LM5 - admin - 09.01.2018 LM5M4p: https://dl.openrb.com/lm-17-imx6/lm5m4-20170620.img Factory reset LM5 - KingCanute - 09.01.2018 Thanks for all the help. Sent fra min SM-N950F via Tapatalk |
