Modbus TCP/IP - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Modbus TCP/IP (/showthread.php?tid=1185) |
Modbus TCP/IP - AndersH - 22.01.2018 Hi, first time to set up a communication Modbus TCP/IP in a HomeLynk. KNX precens detectors should send a 1bit (1/0) to the ventilation system via Modbus, how should i start ? Ventilation system is Modbus slave, and have IP 172.xx.xx.xxx, ID 240, and port 502 This is a script from ventilation system: //mbreg[10001] = 0 //end //Gate 1 slinga 1 addrange g1 11101 11119 remnode g1 11107 //Gate 1 slinga 2 addrange g2 12107 12129 remrange g2 12108 12119 //Gate 2 slinga 1 addrange g3 21101 21127 remnode g3 22114 //Gate 2 slinga 2 addrange g4 22128 22141 remnode g4 22133 //Gate 3 slinga 1 //addrange g5 31101 31116 //Gate 3 slinga 2 //addrange g6 32108 32109 //Gate 4 slinga 1 //Gate 4 slinga 2 foreach n g1 GMR = n - 1100 if mbreg[GMR] equal 1 tassign rep["Nrvarozon" @ n] 71 end if mbreg[GMR] equal 0 restore rep["Nrvarozon" @ n] end next foreach n g2 GMR = n - 2100 if mbreg[GMR] equal 1 tassign rep["Nrvarozon" @ n] 71 end if mbreg[GMR] equal 0 restore rep["Nrvarozon" @ n] end next foreach n g3 GMR = n - 10900 if mbreg[GMR] equal 1 tassign rep["Nrvarozon" @ n] 71 end if mbreg[GMR] equal 0 restore rep["Nrvarozon" @ n] end next foreach n g4 GMR = n - 11900 if mbreg[GMR] equal 1 tassign rep["Nrvarozon" @ n] 71 end RE: Modbus TCP/IP - Daniel - 22.01.2018 Hi There is not enough info here. At last this script is not telling me anything. To which registry do you want to write and via what modbus function? BR RE: Modbus TCP/IP - AndersH - 22.01.2018 If there is no info in the script file from the Ventilation guy leave it... What information do i have to know ? RE: Modbus TCP/IP - Daniel - 22.01.2018 Hi Yes we can create profile and you have info on IP, ID(slave) and port To create profile we need to know registry address and which modbus function to use. BR RE: Modbus TCP/IP - AndersH - 07.02.2018 I solved the problem ![]() Used the Modbus profile description and made a profile with the adresses (registers) that ventilation system used .... imported the profile to HL and added new devise with the profile, after that was only to connect the KNX groupadresses to wright register... File looks like this (but have about 100 registers): { "manufacturer": "Lindinvent", "description": "Lindintell", "mapping": [ { "name": "1065 Driftpers", "bus_datatype": "bool", "datatype": "int16", "type": "register", "address": 10001, "writable": 1 }, { "name": "1067 Tvätt", "bus_datatype": "bool", "datatype": "int16", "type": "register", "address": 10002, "writable": 1 } ] } |
