determine size icon object 255 bytes - Printable Version
+--- Thread: determine size icon object 255 bytes (/showthread.php?tid=1189)
determine size icon object 255 bytes - Daponte - 23.01.2018
How can I limit the size of a text icon on a screen of a 255-byte object?
RE: determine size icon object 255 bytes - admin - 23.01.2018
You can set max-width to limit text size via CSS (Additonal classes):
.myclass {   max-width: 100px;   overflow: hidden;   white-space: nowrap;   text-overflow: ellipsis; }
RE: determine size icon object 255 bytes - Daponte - 24.01.2018
Thank you very much ☺
This class does not work for me, it still has an overflow
RE: determine size icon object 255 bytes - admin - 24.01.2018
Check that Additonal classes is set to myclass without leading dot (should not be .myclass)
