Z-Wave Fibaro Temperature Sensor - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Z-Wave Fibaro Temperature Sensor (/showthread.php?tid=1202) |
Z-Wave Fibaro Temperature Sensor - Bobby - 30.01.2018 Hi! Has anyone tried to link the Fibaro Temp. Sensor with logicmachine? is it possible? https://www.fibaro.com/en/products/the-heat-controller/ Only the temp.sensor, not the radiator thermostat. I Want to use it as Temp.sensor in every room for my knx based water heating system. RE: Z-Wave Fibaro Temperature Sensor - Daniel - 30.01.2018 Hi Check if it is on this list https://github.com/OpenZWave/open-zwave/tree/master/config If you just need temperature then I would consider enocean as you can have sensor without battery. Also much more stable option. BR RE: Z-Wave Fibaro Temperature Sensor - Bobby - 30.01.2018 (30.01.2018, 13:35)Daniel. Wrote: Hi Hi! The reason i wanted the Fibaro, is because of the size of it. about an inch wide. do you have any good looking suggestions? RE: Z-Wave Fibaro Temperature Sensor - Daniel - 30.01.2018 (30.01.2018, 13:58)Bobby Wrote:(30.01.2018, 13:35)Daniel. Wrote: Hi Ask google : ![]() http://www.vesternet.com/nodon-indoor-temperature-sensor#fo_c=521&fo_k=17c5eb8b7e889d04695e7df12f57bc1e&fo_s=gplauk this is small and you can put it anywhere where there is a bit of light. BR |
