Trend viewer remove names - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Trend viewer remove names (/showthread.php?tid=121) |
Trend viewer remove names - PassivPluss - 31.10.2015 Hi There should be a possibility to remove names on trends as they on a little screen with muliple trends hides the start of trends. There is also a 1 hour wrong value on showing day by day trend vs hour by hour. Also a way of rearranging the trends from top to bottom. And to direct show mulitiple preset trends when pushing a button i visu. Like here the floor temp, room temp and set point for heating is shown for two rooms. RE: Trend viewer remove names - Erwin van der Zwart - 31.10.2015 Hi, You can use custom css to hide the trend names on small screens with the @media screen selector. This way you can set a resolution scope when the css rules to hide the names must be applied. Rearrange of the trends is now only possible with script. You need to know SQL then you can run a query on the DB to change the sort order. BR, Erwin van der Zwart |
