1-wire not working - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: 1-wire not working (/showthread.php?tid=1231) |
1-wire not working - Bobby - 11.02.2018 Hi! I tried do connect several 1-wire sensors to the 1-wire output. connected GND + 1-Wire + 5V. like the drawing in the manual. I measured 5V between GND an +5V I measured 0.5V between GND and 1Wire. but my Reactor V3 won't show anything in the web interface... what other possibilities is there to find my fault? BR Bobby RE: 1-wire not working - admin - 11.02.2018 Idle state of 1-wire should be +5V, it's possible that 1-wire chip is damaged. RE: 1-wire not working - Bobby - 11.02.2018 (11.02.2018, 14:59)admin Wrote: Idle state of 1-wire should be +5V, it's possible that 1-wire chip is damaged. Inside the Reactor? (11.02.2018, 15:00)Bobby Wrote:(11.02.2018, 14:59)admin Wrote: Idle state of 1-wire should be +5V, it's possible that 1-wire chip is damaged. what are my options then? RE: 1-wire not working - admin - 12.02.2018 You can send the device back to us for repair, please contact us via e-mail. |
