Nabaztag control - Printable Version
+--- Thread: Nabaztag control (/showthread.php?tid=1247)
Nabaztag control - gilles38 - 22.02.2018
Hi all as a contribution here after you will find my code done to pilot a Nabaztag
as a reminder Nabaztag is a communicating rabbit, that can speak(TTS), play music, move ears, have an embded RFID sensor. I personnaly use it as vocal feedback of my homeautomation system (homelynk based)
--[[ Author: Gilles38 Name: Class_Nabaztag Version: 0.0.1 Design for HomeLYnk and spaceLYnk Available methodes:         Is_Reachable() return boolean                 Is_Connected() return boolean                 Is_Sleeping() return boolean                 Reboot() return true or error message                 SetEars($Pos_Gauche,$Pos_Droite) return true or error message                 Speak($Texte,$Voix)    return true or error message                 Play_Stream($Url) return true or error message          Get_Name()    return string                 Get_Voices()    return array                 Wakeup() return true or error message                 Goto_Sleep() return true or error message Required for constructor:                 Adresse_main:define standard server adresse                 Adresse_Unified: define alternativ server                 Name: is the name of the Rabbit                 Token: define the token of the rabbit                 Mac: Mac adress of the rabbit                 Voice: define the list of voices available ]]-- Nabaztag={Name="",Token="",Mac="", Adresse_Main="", Adresse_Unified="", Voice={}} Nabaztag.__index = Nabaztag --Nabaztag class constructor function Nabaztag:new( o,Name, Token, Mac)  o=o or {}  setmetatable(o, self)  self.Name = Name  self.Token = Token  self.Mac = Mac  self.Adresse_Main="http://openjabnab.fr/ojn/FR/api.jsp"  self.Adresse_Unified="http://api.wizz.cc/?server=pixel"  self.Voices= {"Alice","Antoine","Bruno","Claire","Julie","Margaux","Lorise","Deepa","Graham","Lucy","Peter","Rachel"}  log("Creation classe name:"..self.Name.." Token:"..self.Token)  return o end --Send standard command  to Nabaztag return true or false function Nabaztag:Send_Command(action)   Query=self.Adresse_Main.."?sn="..self.Mac.."&token="..self.Token.."&action="..action  return(self:Launch_Query(Query)) end function Nabaztag:Launch_Query(Query)  log("Launch-Query")  require ("socket")     require ("socket.http")  respResult, respcode, respHeaders, respStatus = socket.http.request(Query)  return(respResult) end --************Get Rabbit name********** function Nabaztag:Get_name()  return(self.Name) end --**********Get voices available******* function Nabaztag:Get_Voices()  return(self.Voices) end --************Goto slip**************** function Nabaztag:Goto_Sleep()  return(self:Send_Command(14)) end   --**********Make the rabbit wakeup********** function Nabaztag:Wakeup()    return(self:Send_Command(13)) end --*********Play sounds from URL*********** function Nabaztag:Play_Stream(Url)  Query=self.Adresse_Unified.."&sn="..self.Mac.."&token="..self.Token.."&urlList="..Url  result=self:Launch_Query(Query) end --********Make the rabbit speak********** function Nabaztag:Speak(Text,Voice)      --*******Url encode**********   if (Text) then      Text = string.gsub (Text, "\n", "\r\n")      --Text = string.gsub (Text, "([^%w ])",        -- function (c) return string.format ("%%%02X", string.byte(c)) end)    Text = string.gsub (Text, " ", "+")    Text=string.gsub(Text,"é","%%%e9")    Text=string.gsub(Text,"è","%%%e8")    Text=string.gsub(Text,"ç","%%%e7")    Text=string.gsub(Text,"ê","%%%ea")    Text=string.gsub(Text,"ô","%%%f4")    Text=string.gsub(Text,"� ","%%%e0")    Text=string.gsub(Text,"â","%%%e2")    Text=string.gsub(Text,"?","%%%3f")    Text=string.gsub(Text,":","%%%3a")   end  log(Text)  Query=self.Adresse_Unified.."&sn="..self.Mac.."&token="..self.Token.."&tts="..Text.."&ws_acapela="..Voice  result=self:Launch_Query(Query) end --*******Ears position changing**************** --*******Parameters: Left ears, right ears value from 0 to 16 --*******return tru if OK else an error message function Nabaztag:SetEars(Pos_Gauche,Pos_Droite)  if(Pos_Gauche>16) then    Pos_Gauche=16  end    if(Pos_Droite>16) then    Pos_Droite=16  end    Query=self.Adresse_Main.."&sn="..self.Mac.."&token="..self.Token.."&posleft="..Pos_Gauche.."&posright="..Pos_Droite  result=self:Launch_Query(Query) end --*****Reboot rabbit********* function Nabaztag:Reboot()  return(self:Send_Command(17)) end --*********Check if rabbit is connected******** function Nabaztag:Is_Connected()  if(self:Send_Command(15)~=nil) then      if (string.find(self:Send_Command(15),"YES") ~= nil) then        return(true)         else        return(false)         end  else    return(false)  end end --*********Check if rabbit is sleeping******** function Nabaztag:Is_Sleeping()  if (string.find(self:Send_Command(7),"YES") ~= nil) then    return(true)     else    return(false)     end end --*********Check if rabbit can launch an action******** function Nabaztag:Is_Reachable()     return(self:Is_Sleeping() and self:Is_Connected()) end function  Nabaztag:Status()    if(self:Is_Connected()) then    if(self:Is_Sleeping()) then      return(2)    else      return(1)    end  else    return (0)  end   end
RE: Nabaztag control - admin - 22.02.2018
Nice, one small suggestion: have you tried using socket.url.escape instead of multiple string.gsub? It should handle other language-specific characters as well.
RE: Nabaztag control - gilles38 - 22.02.2018
(22.02.2018, 11:29)admin Wrote: Nice, one small suggestion: have you tried using socket.url.escape instead of multiple string.gsub? It should handle other language-specific characters as well.
thanks I will try Wink  and update the code accordingly.
