if (two conditions) then - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: if (two conditions) then (/showthread.php?tid=1283) |
if (two conditions) then - 02dag - 11.03.2018 Hi, I have made a script with two conditions that need to be fulfilled before doing something. I have tried everything bt it is not working. There are no syntax errors now and I disable/enable every time I save scripts just to be sure. The script reads a value from a illumination sensor and status from a light object. Then it compares the two and writes to the same light object. Here it is: Code: illumivalue = grp.getvalue('32/1/3')
switchvalue = grp.getvalue('0/4/10')
if (illumivalue <= 5 and switchvalue == 0) then
grp.write('0/4/10',1)
elseif (illumivalue >= 5 and switchvalue == 1)
then grp.write('0/4/10',0)
endRE: if (two conditions) then - buuuudzik - 11.03.2018 (11.03.2018, 00:04)02dag Wrote: Hi, Change this line: Code: if (illumivalue <= 5 and switchvalue == false) thenRE: if (two conditions) then - 02dag - 11.03.2018 (11.03.2018, 00:21)buuuudzik Wrote:(11.03.2018, 00:04)02dag Wrote: Hi, Thank you very much. This worked, but I am puzzled. I thought that you could use both 0/1 or /true/false for things like this? Never thought of the latter for this script though. RE: if (two conditions) then - buuuudzik - 11.03.2018 (11.03.2018, 10:59)02dag Wrote:(11.03.2018, 00:21)buuuudzik Wrote:(11.03.2018, 00:04)02dag Wrote: Hi, You can check that type(false) is 'boolean' and type(0) is 'number'. If you aren't sure of type of variable you can use toboolean function. Check this: Code: log(type(false))
log(type(0))
log(type(toboolean(0)))RE: if (two conditions) then - Erwin van der Zwart - 11.03.2018 Hi, true/false or 1/0 does not matter for writing, when comparing something it (offcourse) cannot be both (: Tip: If result of a condition is not what you expect, log the variables to see what is going on.. BR, Erwin |
