3 Byte converter - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: 3 Byte converter (/showthread.php?tid=1296) |
3 Byte converter - Domoticatorino - 17.03.2018 Hi, I have a knx device which sent 3 byte telegram. I have to split 3 byte in 3 section of 1 byte. Then I need to verify the status of every single bit from bit 0 to 15 bit. What do you suggest? Thanks. RE: 3 Byte converter - Erwin van der Zwart - 17.03.2018 Hi, There are multiple items on this forum about these 2 topics, please use the search option. BR, Erwin RE: 3 Byte converter - Domoticatorino - 17.03.2018 Hi Erwin, you're right. Sometimes the rush blurs the mind. |
