4-bit to 1-byte conversion script for DALI, DMX512 etc. - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: 4-bit to 1-byte conversion script for DALI, DMX512 etc. (/showthread.php?tid=13) |
4-bit to 1-byte conversion script for DALI, DMX512 etc. - edgars - 02.07.2015 Resident script (sleep interval = 0), which is doing conversion from 4-bit to 1-byte 4-bit dimmer object adress is 1/1/1 1-byte output object adress is 1/1/2 By default, script will change value by 10% every 0.2 seconds when any kind of up/down telegram is received. Code: dimmer = grp.getvalue('1/1/1')
step = bit.band(dimmer, 0x07)
if step ~= 0 then
addr = '1/1/2'
up = bit.band(dimmer, 0x08) ~= 0
value = grp.getvalue(addr)
if up then
newvalue = value + 10
newvalue = value - 10
-- clamp between 0 and 100
newvalue = math.min(newvalue, 100)
newvalue = math.max(newvalue, 0)
if newvalue ~= value then
grp.write(addr, newvalue)
os.sleep(0.2)RE: 4-bit to 1-byte conversion script for DALI, DMX512 etc. - DarthPaul - 16.09.2016 (02.07.2015, 08:32)edgars Wrote: Resident script (sleep interval = 0), which is doing conversion from 4-bit to 1-byte I just cant make this work. I get an message: Lua syntax error at line 6: '=' expected near 'up' It might just be too late at night... edit: Sorry.. just found the error... When copying your code RAW, and replacing it with my group addresses, something happened with the spaces.. When I deleted all space before code.. It worked.. adding space, still works?.. anyway, some copy-problems, works superb now.. thanks Dont underestimate the Power of KNX Darth Paul RE: 4-bit to 1-byte conversion script for DALI, DMX512 etc. - david.rombaut@gmail.com - 06.10.2018 Hello, I've been using this script succesfully for about 2 years to be able to control the volume of my Sonos system directly from KNX Berker pushbuttons. I now tried to do the same thing to make simulatious dimming of multiple lights from 1 button possible but for some reason I am getting an error message: "bad argument, number expected, got boolean) I've checked in ETS and address '2/1/17' is defined as 4 bit. Anybody an idea on what I might be doing wrong here? Thanks, David RE: 4-bit to 1-byte conversion script for DALI, DMX512 etc. - admin - 06.10.2018 Check that 2/1/17 has 4-bit type in LM Objects tab, ETS settings does not matter RE: 4-bit to 1-byte conversion script for DALI, DMX512 etc. - david.rombaut@gmail.com - 06.10.2018 (06.10.2018, 12:42)admin Wrote: Check that 2/1/17 has 4-bit type in LM Objects tab, ETS settings does not matter Yep, that did the trick. Thanks a lot. Forgot that I have to define the objects in both ETS and LM
RE: 4-bit to 1-byte conversion script for DALI, DMX512 etc. - Daniel - 03.06.2021 Change the +10, -10 in the code as you need RE: 4-bit to 1-byte conversion script for DALI, DMX512 etc. - victor.back - 03.06.2021 (03.06.2021, 08:29)Daniel. Wrote: Change the +10, -10 in the code as you need Thanks. I think that I missed the os.sleep was at 5sec, so changed it to 1sec. Havent been able to try it out, but think that this was my issue ![]() EDIT: I found that my issu was that I had set up an event based script, so this was just executed once, now I changed it to a resident script insted. |
