help about write data RS232 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: help about write data RS232 (/showthread.php?tid=1318) |
help about write data RS232 - datbui - 29.03.2018 Hello, I'm starting to work with logic machine, I've been connecting the logic machine to a pc through the rs232 port, I could write from the logic machine to a pc terminal, but result is wrong with string I wrote. P/S: I conect LM5 Re:actor with PC by Board USB to USART. Thank you. RE: help about write data RS232 - admin - 29.03.2018 Check baud rate, stop bits and parity settings. Defaults for serial library are 115200, 1 stop bit, no parity. RE: help about write data RS232 - datbui - 29.03.2018 (29.03.2018, 09:34)admin Wrote: Check baud rate, stop bits and parity settings. Defaults for serial library are 115200, 1 stop bit, no parity. Thank you for your replay! I checked, I use : Baud rate 115200, 1 stop bit, no parity. I wrote string 'gh', Result: ' L'. Thanks you. My code in Resident: if not port then require('serial') port = serial.open('/dev/RS232', { baudrate =115200 }) port:flush() line = '' end port:write('gh') RE: help about write data RS232 - admin - 29.03.2018 Are you sure you have USB-RS232 adapter? You might have USB-UART (TTL) which can be easily damaged if connected to RS-232 port. RE: help about write data RS232 - datbui - 30.03.2018 (29.03.2018, 10:36)admin Wrote: Are you sure you have USB-RS232 adapter? You might have USB-UART (TTL) which can be easily damaged if connected to RS-232 port. I use board USB to USART (chip CP2102- TTL) and use board STM32F4 discovery communicate by USART, both result same. Thanks for help. |
